주요 콘텐츠로 건너뛰기
Dell Vostro 5459 Hard Drive Replacement
Johnathan Hammond
Johnathan Hammond다른 한 명의 기여자
최종 수정일 November 4, 2019
9 - 20 분
조정
커뮤니티-기여 안내서
필요한 것
도구
더보기...
  1. Dell Vostro 5459 Hard Drive Replacement, Removing the Base Cover: 1 단계, 이미지 1개 중 1개
    • Remove the screws that secure the back cover to the computer.
    • Pry the edges of the back cover from all sides, to release the back cover.
    • Lift the back cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5459 Hard Drive Replacement, Removing the Battery: 2 단계, 이미지 1개 중 1개
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift and remove the battery from the computer [3].
  3. Dell Vostro 5459 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1개 중 1개
    • Disconnect the hard drive cable from the connector on the system board [1] .
    • Remove the screws that secure the hard drive to the computer [2].
    • Lift the hard drive from the computer [3].
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,237 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 한 개
Dell Vostro 14 5459 definitely is simple and easy to open. In absence of prying tool you can use even disposable plastic knife. Spent 15 minutes to disassemble, change HDD drive to SSD drive and assemble it back. Memory upgrade is easy as well - carefully peel off plastic sheet above RAM module and replace the RAM. Seems particular cooler design is not very prone to collect dust inside too so easier cleaning as well. If middle screw on assembly doesn’t stick in thread, slightly press keyboard in area where keys G,H,J are and try to screw the screw in again. For maintenance and upgrade for this laptop I give 4/5.
Jānis Baumanis - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 1,125
