주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell XPS 14 Fan Replacement
필요한 것
  1. Dell XPS 14 Fan Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Position the computer back side up so that the “XPS” logo is facing you.
    • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
    댓글 쓰기
  2. Dell XPS 14 Fan Replacement: 2 단계, 이미지 3개 중 1개 Dell XPS 14 Fan Replacement: 2 단계, 이미지 3개 중 2개 Dell XPS 14 Fan Replacement: 2 단계, 이미지 3개 중 3개
    • Use an opening tool to pry up the metal plate.
    • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
    댓글 쓰기
  3. Dell XPS 14 Fan Replacement: 3 단계, 이미지 2개 중 1개 Dell XPS 14 Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Use an opening tool to pop out the back panel.
    • Once unhinged, the panel will open away from you.
    • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
    댓글 쓰기
  4. Dell XPS 14 Fan Replacement: 4 단계, 이미지 3개 중 1개 Dell XPS 14 Fan Replacement: 4 단계, 이미지 3개 중 2개 Dell XPS 14 Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Flip over the back panel so that the interior of the panel is facing up.
    • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
    • Remove the black plastic cover that holds the disk in place.
    • Remove the back panel.
    • The GCE disk should still be connected to the computer via a purple ribbon cable.
    댓글 쓰기
  5. Dell XPS 14 Fan Replacement, Speaker: 5 단계, 이미지 2개 중 1개 Dell XPS 14 Fan Replacement, Speaker: 5 단계, 이미지 2개 중 2개
    • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
    댓글 쓰기
  6. Dell XPS 14 Fan Replacement: 6 단계, 이미지 2개 중 1개 Dell XPS 14 Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the speaker from its original location so the wire connector is visible.
    • Unplug the red and white cable plug by pulling out the white end tag.
    • The speaker is now fully removed.
    댓글 쓰기
  7. Dell XPS 14 Fan Replacement, Battery: 7 단계, 이미지 1개 중 1개
    • Make sure to ground yourself before removing the battery.
    • Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
    • Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
    댓글 쓰기
  8. Dell XPS 14 Fan Replacement: 8 단계, 이미지 3개 중 1개 Dell XPS 14 Fan Replacement: 8 단계, 이미지 3개 중 2개 Dell XPS 14 Fan Replacement: 8 단계, 이미지 3개 중 3개
    • Detach the battery connector from the motherboard using two thumbs to pop it out.
    • Remove the battery from the laptop.
    댓글 쓰기
  9. Dell XPS 14 Fan Replacement, Fan: 9 단계, 이미지 1개 중 1개
    • Remove the two 2 mm screws from the fan using a Phillips #0 screwdriver.
    댓글 쓰기
  10. Dell XPS 14 Fan Replacement: 10 단계, 이미지 2개 중 1개 Dell XPS 14 Fan Replacement: 10 단계, 이미지 2개 중 2개
    • Use two thumbs to pop out the plug that connects the fan to the laptop.
    • Remove the fan from the laptop.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Gabriella Monico
회원 가입일: 03/23/22
457 평판
안내서 5개를 작성함
UMass Dartmouth, Team 1-3, Botvin Spring 2022 UMass Dartmouth, Team 1-3, Botvin Spring 2022 회원
UMASSD-BOTVIN-S22S1G3
3 회원들
안내서 5개를 작성함
1가이드 댓글
Thanks for sharing! One question: Isn't it sufficient to just remove the plug of the battery?
Thomas - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 28
전체 시간: 542
