주요 콘텐츠로 건너뛰기
Dell XPS 15 9500 Base Panel Replacement
Connor
Connor2 다른 기여자
최종 수정일 June 7, 2024
1 - 3 분
쉬움
Welcome to the Dell XPS 15 9500 Base Panel Replacement guide. Here, we'll walk you through safely removing and replacing the base panel on your laptop. This repair might be necessary if your laptop has suffered damage from drops or impacts, or if you need access to internal components like the battery or storage drive. Additionally, cleaning the base panel can improve airflow, helping to resolve overheating or performance issues.
필요한 것
도구
  1. Dell XPS 15 9500 Base Panel Replacement, Base Panel: 1 단계, 이미지 1개 중 1개
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 Base Panel Replacement: 2 단계, 이미지 2개 중 1개 Dell XPS 15 9500 Base Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
결론
작성자
2다른 기여자 명과 함께
Connor
회원 가입일: 03/29/22
12,218 평판
안내서 64개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,470개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 62
전체 시간: 2,797
