주요 콘텐츠로 건너뛰기
Dell XPS 15 9510 Speakers Replacement
Bethany Wright
Bethany Wright6 다른 기여자
최종 수정일 January 7, 2025
15 분
조정
더 많은 이미지가 필요함
Audio issues or sound failure in the Dell XPS 15 9510 indicates that the speakers located on either side of the laptop may need replacement. There are no special skills involved in the removal of the speakers.
Before using this guide, make sure to review the troubleshooting page to ensure that the speaker doesn't have any driver or any other issues.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
필요한 것
부품
도구
더보기...
  1. Dell XPS 15 9510 Speakers Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Speakers Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Speakers Replacement, Speakers: 4 단계, 이미지 3개 중 1개 Dell XPS 15 9510 Speakers Replacement, Speakers: 4 단계, 이미지 3개 중 2개 Dell XPS 15 9510 Speakers Replacement, Speakers: 4 단계, 이미지 3개 중 3개
    • Remove the 4 pieces of black tape holding the speaker wire in place.
  5. Dell XPS 15 9510 Speakers Replacement: 5 단계, 이미지 2개 중 1개 Dell XPS 15 9510 Speakers Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 2.5 mm screws holding the speakers in place using a Phillips #0 screwdriver.
  6. Dell XPS 15 9510 Speakers Replacement: 6 단계, 이미지 2개 중 1개 Dell XPS 15 9510 Speakers Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Lift the black tape that covers the power supply pin plug.
    • Remove the plug using a small pair of tweezers. Be sure to not damage any wiring.
  7. Dell XPS 15 9510 Speakers Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the speakers up from the securing pins.
  8. Dell XPS 15 9510 Speakers Replacement: 8 단계, 이미지 2개 중 1개 Dell XPS 15 9510 Speakers Replacement: 8 단계, 이미지 2개 중 2개
    • Begin removing the wire from the track on the computer body.
    • Now the speakers will be fully disconnected from the computer.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Bethany Wright
회원 가입일: 07/13/23
439 평판
안내서 3개를 작성함
IUPUI, Team 2-1, Harley Summer 2023 IUPUI, Team 2-1, Harley Summer 2023 회원
IUPUI-HARLEY-SU23S2G1
4 회원들
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 259
