Dell XPS 15 9560 Touchpad Replacement
How to replace a scratched, cracked, or unresponsive trackpad on a Dell XPS 15 9560 laptop.
Before using this guide, check for other possible causes of trackpad issues.
- Trackpad Drivers: Your issue may be related to drivers. Watch this video by MDTechVideos for a fix.
- Dust or Debris: Clean the trackpad by spraying isopropyl alcohol on a microfiber cloth. Apply medium pressure and wipe in small circles on and around the trackpad.
필요한 것
도구
더보기...
Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
Unplug the hard drive cable.
Gently pull the white ribbon cables out from their housings. To disconnect, use a spudger or your fingernail to gently lift the looped tab away from the connector. It should pop up easily.
Next, use the spudger or your fingernail to push the plastic tab away from the socket. It should move slightly.
Now, pull the white ribbon cables out.
