주요 콘텐츠로 건너뛰기
Dell XPS 15-L502X Front Cover Replacement
Kyle Compton
Kyle Compton7 다른 기여자
최종 수정일 September 14, 2020
5 - 30 분
쉬움
액션 샷
This guide will help you remove the front panel of your laptop. Removing the front panel can expose many delicate components of the laptop, so it's important to be gentle and cautious of static when working through this guide.
필요한 것
도구
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Dell XPS 15-L502X Front Cover Replacement, Front Cover: 1 단계, 이미지 1개 중 1개
    • Before prying up on the cover, you may have to first remove a screw located inside the battery compartment (M2X3) and release the two latches. If you don't release the latches, you may snap the cover.
    • Pry up the top of the cover first by using a spudger to wedge in between the cover and base of the computer.
    • Once the spudger is between the cover and the base of the computer, wedge underneath the remaining border surrounding the keyboard.
    • Cracking sounds are normal. Be careful and take your time removing this panel.
  2. Dell XPS 15-L502X Front Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Work your fingers underneath the cover. Then, delicately pull the cover off of the computer.
    • The mouse pad is connected to the rest of the computer via two cables underneath the cover. These cables must be unhooked before the cover can be completely removed.
  3. Dell XPS 15-L502X Front Cover Replacement: 3 단계, 이미지 2개 중 1개 Dell XPS 15-L502X Front Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Unhook the cables connected to the mouse pad by flipping up the black tabs that hold either cable in place.
    • Releasing these cables can be done by hand or by using a spudger.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Kyle Compton
회원 가입일: 09/16/15
416 평판
안내서 1개를 작성함
IUPUI, Team 2-3, Baechle Fall 2015 IUPUI, Team 2-3, Baechle Fall 2015 회원
IUPUI-BAECHLE-F15S2G3
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 28
전체 시간: 2,913
