주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Determining Wire Connectivity for Skullcandy Lowrider
필요한 것
    1. Determining Wire Connectivity for Skullcandy Lowrider, Checking to See if the Wire is Still Connected to the Ear-Cup: 1 단계, 이미지 2개 중 1개 Determining Wire Connectivity for Skullcandy Lowrider, Checking to See if the Wire is Still Connected to the Ear-Cup: 1 단계, 이미지 2개 중 2개
      • Pull the edge of the pad where it meets the plastic of the ear-cup to separate the padding from the ear pad.
      댓글 쓰기
    2. Determining Wire Connectivity for Skullcandy Lowrider: 2 단계, 이미지 2개 중 1개 Determining Wire Connectivity for Skullcandy Lowrider: 2 단계, 이미지 2개 중 2개
      • Use the small Phillips screwdriver to remove three 8mm screws on the surface of the earphones.
      댓글 쓰기
    3. Determining Wire Connectivity for Skullcandy Lowrider: 3 단계, 이미지 1개 중 1개
      • Now that the screws have been removed, use your hands to separate the plate from the rest of headphone.
      • Here, you will be able to check the connectivity of your auxiliary cord to its port in an appropriate ear-cup.
      댓글 쓰기
    4. Determining Wire Connectivity for Skullcandy Lowrider: 4 단계, 이미지 1개 중 1개
      • Now that you have removed the plate you can check the wiring connectivity. If the wire is not connected to any sources inside the ear-cup, as shown in the image to the right, then this is the reason that your headphone(s) are not working.
      • Now that you have verified your problem, refer to the guide Skullcandy Lowrider Wiring Repair to fix the loose wiring.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Ryley
회원 가입일: 01/16/15
273 평판
안내서 3개를 작성함
USF Sarasota-Manatee, Team 1-2, Stewart Winter 2015 USF Sarasota-Manatee, Team 1-2, Stewart Winter 2015 회원
USFSM-STEWART-W15S1G2
4 회원들
안내서 27개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 43
전체 시간: 1,495
