주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DigiLand DL1010Q Battery Replacement
필요한 것
    1. DigiLand DL1010Q Battery Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
      • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
      • Before disassembling your device, be sure it is powered off.
      댓글 쓰기
    2. DigiLand DL1010Q Battery Replacement: 2 단계, 이미지 2개 중 1개 DigiLand DL1010Q Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
      • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
      댓글 쓰기
    3. DigiLand DL1010Q Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully lift back panel away from the body of the device.
      • Speaker wires are connected to both the front and back panel.
      댓글 쓰기
    1. DigiLand DL1010Q Battery Replacement, Battery: 4 단계, 이미지 2개 중 1개 DigiLand DL1010Q Battery Replacement, Battery: 4 단계, 이미지 2개 중 2개
      • Desolder positive and negative, red and black, wires from the mother board that are connected to the battery.
      • The soldering tool is hot, and will burn. For how to use a soldering tool follow the How to Solder Guide
      댓글 쓰기
    2. DigiLand DL1010Q Battery Replacement: 5 단계, 이미지 2개 중 1개 DigiLand DL1010Q Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Using a metal spudger tool, wedge between battery and metal screen.
      • Follow the edge of the battery to loosen the glue.
      댓글 쓰기
    3. DigiLand DL1010Q Battery Replacement: 6 단계, 이미지 2개 중 1개 DigiLand DL1010Q Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Once the glue is loosened, you should be able to pry off the battery from the screen.
      • Using your hands, pull up on the battery to pull battery off.
      • Pulling on the battery causes you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
      • The battery will be completely disconnected and you can set the battery aside in a safe place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Faith Lebo
회원 가입일: 09/28/15
212 평판
안내서 1개를 작성함
3가이드 댓글
the replacemet has 3 wires .where go the 3 wire?
javier perez - 답글 공유
were can i buy a new  bettery
Theresa - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 22
전체 시간: 5,015
