주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DigiLand DL718M Screen Replacement
필요한 것
  1. DigiLand DL718M Screen Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Remove back panel by wedging the iFixit opening tool on all four sides of the device.
    댓글 쓰기
  2. DigiLand DL718M Screen Replacement, Screen: 2 단계, 이미지 1개 중 1개
    • Remove two silver Phillips #0 screws along the bottom of the internal panel.
    댓글 쓰기
  3. DigiLand DL718M Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the ribbon in the bottom left corner of the motherboard by lifting the black tab and sliding the ribbon out from the slot underneath the black tab.
    댓글 쓰기
  4. DigiLand DL718M Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the small, circular microphone on the left side of the device by sliding it out of its slot using an opening tool.
    댓글 쓰기
  5. DigiLand DL718M Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the front-facing camera in the top left corner of the device by sliding it out of its slot using an opening tool.
    댓글 쓰기
  6. DigiLand DL718M Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the three black Phillips #0 screws along the left side of the motherboard.
    댓글 쓰기
  7. DigiLand DL718M Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Detach the black tape and the wire from the right side of the screen.
    댓글 쓰기
  8. DigiLand DL718M Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the rear-facing camera by prying it off of the back side of the screen using the an opening tool.
    댓글 쓰기
  9. DigiLand DL718M Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the motherboard and remove it from the device using an opening tool.
    • If there is any tape on the device that prohibits you from doing so, remove the tape.
    댓글 쓰기
  10. DigiLand DL718M Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the ribbon above the battery by lifting the black tab and sliding the ribbon out from the slot underneath the black tab using an opening tool.
    댓글 쓰기
  11. DigiLand DL718M Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Pry the battery off of the back of the screen by wedging the iFixit opening tool underneath.
    댓글 쓰기
  12. DigiLand DL718M Screen Replacement: 12 단계, 이미지 2개 중 1개 DigiLand DL718M Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Lift the screen from the plastic casing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Alayna Knarian
회원 가입일: 10/15/19
734 평판
안내서 6개를 작성함
1가이드 댓글
What happen after? How remove the LCD screen? ……..INCOMPLETE
jrtu2001 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 30
전체 시간: 639
