주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Digiland DL1168A Battery Replacement
필요한 것
  1. Digiland DL1168A Battery Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
    댓글 쓰기
  2. Digiland DL1168A Battery Replacement: 2 단계, 이미지 2개 중 1개 Digiland DL1168A Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
    댓글 쓰기
  3. Digiland DL1168A Battery Replacement: 3 단계, 이미지 2개 중 1개 Digiland DL1168A Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
    댓글 쓰기
  4. Digiland DL1168A Battery Replacement, Battery: 4 단계, 이미지 3개 중 1개 Digiland DL1168A Battery Replacement, Battery: 4 단계, 이미지 3개 중 2개 Digiland DL1168A Battery Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • Desolder the three positive, negative, and neutral red, black, and white wires from the motherboard that are connected to the battery.
    • The soldering tool is hot, and will burn. Follow this link for instructions on 연결부 납땜 및 납제거 방법.
    댓글 쓰기
  5. Digiland DL1168A Battery Replacement: 5 단계, 이미지 2개 중 1개 Digiland DL1168A Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Using an opening tool, separate the battery from the tablet.
    • Follow the edge of the battery to loosen the glue.
    댓글 쓰기
  6. Digiland DL1168A Battery Replacement: 6 단계, 이미지 3개 중 1개 Digiland DL1168A Battery Replacement: 6 단계, 이미지 3개 중 2개 Digiland DL1168A Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Once the glue is loosened, pry the battery away from the screen.
    • Pulling on the battery may cause you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ryan Barker
회원 가입일: 10/15/19
217 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 21
전체 시간: 624
