주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Digiland DL1168A Front/Rear Camera Replacement
필요한 것
  1. Digiland DL1168A Front/Rear Camera Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
    댓글 쓰기
  2. Digiland DL1168A Front/Rear Camera Replacement: 2 단계, 이미지 2개 중 1개 Digiland DL1168A Front/Rear Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
    댓글 쓰기
  3. Digiland DL1168A Front/Rear Camera Replacement: 3 단계, 이미지 2개 중 1개 Digiland DL1168A Front/Rear Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
    댓글 쓰기
  4. Digiland DL1168A Front/Rear Camera Replacement, Front/Rear Camera: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to remove the cover that keeps the camera lens in place.
    댓글 쓰기
  5. Digiland DL1168A Front/Rear Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Use tweezers to gently begin to lift the back piece off.
    • Lift gently because the lens is connected to the back piece by a small cord.
    댓글 쓰기
  6. Digiland DL1168A Front/Rear Camera Replacement: 6 단계, 이미지 1개 중 1개
    • After lifting gently both the lens and the back piece will be removed.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Payton Boshears
회원 가입일: 10/15/19
97 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 23
전체 시간: 336
