주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Logitech MBJ58 Mouse Scroll wheel from mount
필요한 것
    1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Top cover: 1 단계, 이미지 1개 중 1개
      • Hold the mouse so that the bottom is facing up.
      • Remove the single Phillips #1 screw from the bottom half of the mouse.
      댓글 쓰기
    2. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 2 단계, 이미지 2개 중 1개 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 2 단계, 이미지 2개 중 2개
      • Place the mouse so that the bottom is resting against a hard surface.
      • Lift the top cover of the mouse gently, and remove it.
      댓글 쓰기
    1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 3 단계, 이미지 3개 중 1개 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 3 단계, 이미지 3개 중 2개 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 3 단계, 이미지 3개 중 3개
      • Locate the scroll wheel on the mouse.
      • Grab the scroll wheel with your thumb and index finger.
      • Gently lift up, to remove the scroll wheel from the mouse.
      댓글 쓰기
    1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: 4 단계, 이미지 2개 중 1개 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: 4 단계, 이미지 2개 중 2개
      • Locate the spring on the scroll wheel, and carefully remove the spring.
      댓글 쓰기
    2. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: 5 단계, 이미지 2개 중 1개 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: 5 단계, 이미지 2개 중 2개
      • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
      댓글 쓰기
    1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 6 단계, 이미지 3개 중 1개 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 6 단계, 이미지 3개 중 2개 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 6 단계, 이미지 3개 중 3개
      • Use the images to locate where the resistance spring is.
      • This spring will easily fall off.
      • Grab the scroll wheel and its mount and gently pull them apart.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Maximilian Betkowski
회원 가입일: 01/11/13
238 평판
안내서 4개를 작성함
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 회원
CPSU-FORTE-W13S5G14
5 회원들
안내서 56개를 작성함
7가이드 댓글
Excellent! I took an MBJ58 apart to remove accumulated gunk, and the resistance spring jumped onto my worktable before I noticed where it came from. Thanks for the help, well done!
Marty Swartz - 답글 공유
Heh, me too. Couldn't for the life of me figure out how it went back in. Thanks for the guide!
Steve Bennett - 답글 공유
Same thing happened to me...saved me a trip to the store for a new mouse!!
thanks for taking the time to post these photos!
Bill McFarland - 답글 공유
huh, thank you very much, amazing guide, the only for this product in Internet , and amazingly accurate
leartzajmi - 답글 공유
the resistence spring falled off on mine how do i out it back on help
Tay Carr - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 72
전체 시간: 8,924
