주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Logitech MX Mechanical
필요한 것
    1. Disassembling Logitech MX Mechanical, Remove keycaps: 1 단계, 이미지 2개 중 1개 Disassembling Logitech MX Mechanical, Remove keycaps: 1 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      Keycap Puller
      $6.95
      • Use a keycap remover tool / opening tool or your hands to remove all keycaps.
      • Make a few photos of your keybord layout to have a reference for reassembly later on.
      • If your keybord is dirty use a soft brush to clean it.
      댓글 쓰기
    2. Disassembling Logitech MX Mechanical, Unscrew 20x black screws: 2 단계, 이미지 2개 중 1개 Disassembling Logitech MX Mechanical, Unscrew 20x black screws: 2 단계, 이미지 2개 중 2개
      • Remove 20x black screws with a Philips size 0 screwdriver.
      • Don't loose the screws, put them in a bin or similar.
      댓글 쓰기
    3. Disassembling Logitech MX Mechanical, Open back cover: 3 단계, 이미지 3개 중 1개 Disassembling Logitech MX Mechanical, Open back cover: 3 단계, 이미지 3개 중 2개 Disassembling Logitech MX Mechanical, Open back cover: 3 단계, 이미지 3개 중 3개
      • The back cover is held in place by small plastic tabs.
      • Flip the keyboard on its front.
      • There is a small slid between the back cover and the body. Insert a thin plastic opening pick at the top of the keyboard.
      • Use something sturdy, like a metal spudger to release the plastic tabs all around.
      • There is a cable comming from the battery and connecting the plastic cover and the keyboard front. The connecter is clipped into the plastic frame above the PCV and can be unclipped using some tweezers or spudger.
      댓글 쓰기
    4. Disassembling Logitech MX Mechanical, Remove plastic frame above PCB: 4 단계, 이미지 3개 중 1개 Disassembling Logitech MX Mechanical, Remove plastic frame above PCB: 4 단계, 이미지 3개 중 2개 Disassembling Logitech MX Mechanical, Remove plastic frame above PCB: 4 단계, 이미지 3개 중 3개
      • Disconnect controller from battery.
      • Disconnect ribbon cable from controller.
      • The plastic frame above the PCB is connected via screws. Unscrew 6x silver screws using a size 2 philips screwdriver.
      • Remove the black plastic frame covering the PCB.
      댓글 쓰기
    5. Disassembling Logitech MX Mechanical, (Optional) Remove screws holding PCB: 5 단계, 이미지 2개 중 1개 Disassembling Logitech MX Mechanical, (Optional) Remove screws holding PCB: 5 단계, 이미지 2개 중 2개
      • There are 4 capped screws (silver) fixing the PCB to the metal part of the keyboard. One hides under the ribon cable.
      • Removing the switches isn't covered by this guide.
      • The switches for this model are Kailh Choc V2 Low Profile Switches.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
AnHeuermann
회원 가입일: 08/26/24
438 평판
안내서 2개를 작성함
5가이드 댓글
Super vielen Dank. Wenn du mir jetzt noch sagen kannst, was ich machen muss, damit die Tastaturbeleuchtung immer an bleibt, wäre einfach cool
MasterOfTorment - 답글 공유
Can you publish a guide that shows how to best replace the switches? I have one switch that needs replacement, "9/". Thank you.
rrh - 답글 공유
@rrh87863 you mean like https://de.ifixit.com/Anleitung/Logitech... ?
It's in German and I didn't had the time to translate into English yet, but I'm sure your browser can translate it.
AnHeuermann - 답글 공유
I would like to replace the batter since mine stopped charging, is that doable?
stephendeo - 답글 공유
Hi Stephen,
Another user reported that replacing the battery in the mini version is the same as the full-sized keyboard (guide here). We don't know if the two keyboards use the same battery, though. If you have the chance, creating a guide for this would help everybody out!
Connor Bassolino - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 23
지난 7일: 115
지난 30일: 503
전체 시간: 9,995
