주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Nokia X2-00
필요한 것
    1. Disassembling Nokia X2-00, Nokia X2-00 Background Info: 1 단계, 이미지 1개 중 1개
      • it's a cheap low-end Music Phone
      • mine got wet so i decided to clean it up and look inside!
      댓글 쓰기
    2. Disassembling Nokia X2-00, Removing the Battery: 2 단계, 이미지 3개 중 1개 Disassembling Nokia X2-00, Removing the Battery: 2 단계, 이미지 3개 중 2개 Disassembling Nokia X2-00, Removing the Battery: 2 단계, 이미지 3개 중 3개
      • Flip it and pull the tab
      • the metal part should jump right off
      • after that remove the battery and sim card
      댓글 쓰기
    3. Disassembling Nokia X2-00, Diging In!: 3 단계, 이미지 1개 중 1개
      • so i was kinda !#^&@@ off becouse there were no screws!
      • so i tryed to remove the screen protection, and it worked!
      • 1. i did break it
      • 2. there were no screws
      • just don't do that unless you need
      댓글 쓰기
    4. Disassembling Nokia X2-00, Diging In! 2nd attemp!: 4 단계, 이미지 2개 중 1개 Disassembling Nokia X2-00, Diging In! 2nd attemp!: 4 단계, 이미지 2개 중 2개
      • i tried to remove the side panels but that didn't work so i tried on top and it did work (Jimmy worked fine)
      • these clips kind of suck ....it takes lot of force to unclip these )
      • after you unclip it you get that piece
      댓글 쓰기
    5. Disassembling Nokia X2-00, Removing the midframe: 5 단계, 이미지 3개 중 1개 Disassembling Nokia X2-00, Removing the midframe: 5 단계, 이미지 3개 중 2개 Disassembling Nokia X2-00, Removing the midframe: 5 단계, 이미지 3개 중 3개
      • remove these 2 TR6 Screws (mine were a bit blue)
      • open it up (clips on the bottom)
      • i was on Beast-Mode on these annying clips that held like gorilla
      댓글 쓰기
    6. Disassembling Nokia X2-00, Removing the display: 6 단계, 이미지 3개 중 1개 Disassembling Nokia X2-00, Removing the display: 6 단계, 이미지 3개 중 2개 Disassembling Nokia X2-00, Removing the display: 6 단계, 이미지 3개 중 3개
      • Remove the 4 TR6 Screws
      • They are diffrent from the last ones !!! (this one on the right)
      • remove the whole PCB and remove the clips from the display and it should pop off
      댓글 쓰기
    7. Disassembling Nokia X2-00, The Display: 7 단계, 이미지 2개 중 1개 Disassembling Nokia X2-00, The Display: 7 단계, 이미지 2개 중 2개
      • it's TFT 2.2" 240x320 182 ppi Display
      댓글 쓰기
    8. Disassembling Nokia X2-00, The main PCB: 8 단계, 이미지 1개 중 1개
      • anything shiehielded ...and non-replacable ...i don't like that one at all
      • sorry guys i have forgott to make photo of the backside :(
      댓글 쓰기
    9. Disassembling Nokia X2-00, Extra - Mastery pieces & Test: 9 단계, 이미지 2개 중 1개 Disassembling Nokia X2-00, Extra - Mastery pieces & Test: 9 단계, 이미지 2개 중 2개
      • extra steps that you don't need to do
      • 2 of those fell of and i have NO idea where from (and i don't even care)
      • i cleaned it up and powered it up and it works (just make sure you don't short anything)
      댓글 쓰기
    10. Disassembling Nokia X2-00, The END: 10 단계, 이미지 1개 중 1개
      • i don't really like that one becouse it's hard to open and easy to crack plastics
      • but you can replace many things (not anything)
      • i would like USB on doughterboard and less shielding
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mateusz
회원 가입일: 10/20/14
1,525 평판
안내서 2개를 작성함
1가이드 댓글
Well done,come on
Segmenttopten - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 48
전체 시간: 6,069
