주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dragon Touch Y88X Plus Screen Replacement
필요한 것
  1. Dragon Touch Y88X Plus Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Use a plastic opening tool or spudger to carefully open the tablet's outer case. Start at the corners and work your way around. Be gentle to avoid damaging the case or any internal components.
    댓글 쓰기
  2. Dragon Touch Y88X Plus Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Identify the tablet's battery. It is usually a flat, rectangular component connected to the motherboard.
    댓글 쓰기
  3. Dragon Touch Y88X Plus Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully peel the old battery from the adhesive using the Fixit pry tool.
    • Be very cautious not to puncture the battery
    댓글 쓰기
  4. Dragon Touch Y88X Plus Screen Replacement: 4 단계, 이미지 2개 중 1개 Dragon Touch Y88X Plus Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the three 4 mm screws located around the motherboard.
    댓글 쓰기
  5. Dragon Touch Y88X Plus Screen Replacement: 5 단계, 이미지 2개 중 1개 Dragon Touch Y88X Plus Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the ribbon cables that connect the screen to the tablet's motherboard and disconnect them. Make sure to note how these cables are attached so that you can reassemble them correctly later.
    • To remove the ribbons, flip the black switch where they are connected to the motherboard and gently pull the ribbons out.
    댓글 쓰기
  6. Dragon Touch Y88X Plus Screen Replacement: 6 단계, 이미지 2개 중 1개 Dragon Touch Y88X Plus Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use the plastic opening tool or spudger to pry the old screen away from the tablet carefully. Work your way around the edges, applying gentle pressure.
    • To remove the screen, you might need to utilize the metal spudger with the iFixit plastic pry tool.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Craig B
회원 가입일: 10/30/23
262 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-4, Petersen Fall 2023 UMass Dartmouth, Team 1-4, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G4
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 27
전체 시간: 388
