주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Drill Master Heat Gun Power Switch Replacement
필요한 것
    1. Drill Master Heat Gun Power Switch Replacement, Power Switch: 1 단계, 이미지 1개 중 1개
      • Be sure the heat gun is unplugged before starting this process.
      • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
      • You will need a screwdriver extension.
      댓글 쓰기
    2. Drill Master Heat Gun Power Switch Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
      • Don't try to open the casing just yet.
      댓글 쓰기
    3. Drill Master Heat Gun Power Switch Replacement: 3 단계, 이미지 3개 중 1개 Drill Master Heat Gun Power Switch Replacement: 3 단계, 이미지 3개 중 2개 Drill Master Heat Gun Power Switch Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the barrel casing on either end by twisting and pulling each side off.
      댓글 쓰기
    4. Drill Master Heat Gun Power Switch Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
      댓글 쓰기
    5. Drill Master Heat Gun Power Switch Replacement: 5 단계, 이미지 1개 중 1개
      • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
      • Screws do not come out of connector.
      댓글 쓰기
    6. Drill Master Heat Gun Power Switch Replacement: 6 단계, 이미지 1개 중 1개
      • Squeeze the tabs on either side of the power switch to remove from the casing.
      댓글 쓰기
    7. Drill Master Heat Gun Power Switch Replacement: 7 단계, 이미지 2개 중 1개 Drill Master Heat Gun Power Switch Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the black, plastic wire protectors from the end of the power switch.
      댓글 쓰기
    8. Drill Master Heat Gun Power Switch Replacement: 8 단계, 이미지 1개 중 1개
      • Use soldering iron to remove the electrical wiring from the power switch. To replace the power switch, solder the new switch onto the wires.
      • Heating the soldering metal will allow you to pull off the electrical wiring.
      • For a brush-up on proper soldering, check out How to Solder and Desolder Connections.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mikayla Kim
회원 가입일: 01/31/17
532 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 48
전체 시간: 3,975
