주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
EasySMX X15 A,B,X,Y Buttons Replacement
필요한 것
  1. EasySMX X15 A,B,X,Y Buttons Replacement, Bottom Casing: 1 단계, 이미지 2개 중 1개 EasySMX X15 A,B,X,Y Buttons Replacement, Bottom Casing: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
    댓글 쓰기
  2. EasySMX X15 A,B,X,Y Buttons Replacement, Battery: 2 단계, 이미지 3개 중 1개 EasySMX X15 A,B,X,Y Buttons Replacement, Battery: 2 단계, 이미지 3개 중 2개 EasySMX X15 A,B,X,Y Buttons Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Push on alternating sides of the connector to disconnect the red battery cable from the board.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Pull from the tab, not the cables, to avoid damaging them.
    댓글 쓰기
  3. EasySMX X15 A,B,X,Y Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Use a spudger to pry the battery loose from the controller.
    • The battery is glued onto the control board, so it may take a bit of work to release it from the adhesive.
    • Remove the battery.
    • Don't bend or pierce the battery. If the battery is swollen, follow the guidelines outlined in this article.
    댓글 쓰기
  4. EasySMX X15 A,B,X,Y Buttons Replacement, Main Board: 4 단계, 이미지 1개 중 1개
    • Disconnect the vibration motor cables from the connectors on the circuit board.
    • Use a Phillips #00 screwdriver to remove six, 6mm screws from the board.
    댓글 쓰기
  5. EasySMX X15 A,B,X,Y Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Gently lift the board away from the upper casing, maneuvering it around the triggers by lifting it from the bottom, away from the upper casing.
    댓글 쓰기
  6. EasySMX X15 A,B,X,Y Buttons Replacement, A B X Y Buttons: 6 단계, 이미지 2개 중 1개 EasySMX X15 A,B,X,Y Buttons Replacement, A B X Y Buttons: 6 단계, 이미지 2개 중 2개
    • Remove the buttons from inside of the top case.
    • Check the silicone membranes. If your controller has silicone membranes or conductive pads beneath the buttons, ensure these are properly positioned over the buttons. If necessary, replace worn membranes with new ones.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Jhaylen Lozada
회원 가입일: 09/09/24
245 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 51
전체 시간: 845
