주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
EasySMX X15 Main Board Replacement
필요한 것
  1. EasySMX X15 Main Board Replacement, Bottom Casing: 1 단계, 이미지 2개 중 1개 EasySMX X15 Main Board Replacement, Bottom Casing: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
    댓글 쓰기
  2. EasySMX X15 Main Board Replacement, Battery: 2 단계, 이미지 3개 중 1개 EasySMX X15 Main Board Replacement, Battery: 2 단계, 이미지 3개 중 2개 EasySMX X15 Main Board Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Push on alternating sides of the connector to disconnect the red battery cable from the board.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Pull from the tab, not the cables, to avoid damaging them.
    댓글 쓰기
  3. EasySMX X15 Main Board Replacement: 3 단계, 이미지 1개 중 1개
    • Use a spudger to pry the battery loose from the controller.
    • The battery is glued onto the control board, so it may take a bit of work to release it from the adhesive.
    • Remove the battery.
    • Don't bend or pierce the battery. If the battery is swollen, follow the guidelines outlined in this article.
    댓글 쓰기
  4. EasySMX X15 Main Board Replacement, Main Board: 4 단계, 이미지 1개 중 1개
    • Disconnect the vibration motor cables from the connectors on the circuit board.
    • Use a Phillips #00 screwdriver to remove six, 6mm screws from the board.
    댓글 쓰기
  5. EasySMX X15 Main Board Replacement: 5 단계, 이미지 1개 중 1개
    • Gently lift the board away from the upper casing, maneuvering it around the triggers by lifting it from the bottom, away from the upper casing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
ShawnDetiveaux
회원 가입일: 09/09/24
646 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 35
전체 시간: 415
