Echo Brushcutter SRM2620U 2017 Flex Shaft Replacement
This guide shows how to remove and replace the flexible driveshaft (flex shaft) in an Echo SRM-2620U Brushcutter.
This procedure can also be used to access and re-grease the existing flex shaft. This device requires 15 ml (1/2 oz) of lithium-based grease.
Grip the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Use a T30 Torx driver to remove the locating screw from the gear case.
Use a T30 Torx driver to loosen, but not remove, the collar screw securing the main shaft to the gear case.
다른 2명이 해당 안내서를 완성하였습니다.
