주요 콘텐츠로 건너뛰기
Edwin the Duck Motherboard Replacement
Caleb Kim
Caleb Kim3 다른 기여자
최종 수정일 November 11, 2023
10 - 20 분
조정
Edwin the interactive toy cannot work if the central most crucial part of Edwin, which is the motherboard, does not work. If there is water damage, and Edwin is no longer working, this guide will take you through the steps of replacing it.
필요한 것
도구
더보기...
  1. Edwin the Duck Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Edwin the Duck Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Unscrew the four 9mm screws with a T8 screwdriver bit
    • Remove the back plate off
  2. Edwin the Duck Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Edwin the Duck Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin resulting in losing the waterproof cover.
  3. Edwin the Duck Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Using the J1 screwdriver bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Edwin the Duck Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. Remember to open slowly.
  5. Edwin the Duck Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Edwin the Duck Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Using the plastic opening tool pull up the black tab up until it stops.
    • Be careful not to pull up the black tab too far up, otherwise the cable won't be secure anymore.
    • Pull up the white cable tab, up slowly
  6. Edwin the Duck Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Use the J1 screwdriver bit to unscrew all four 9 mm screws attached to the motherboard.
  7. Edwin the Duck Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the top connector as you see in the picture.
    • Replace the new motherboard and you are finished.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Caleb Kim
회원 가입일: 10/18/17
143 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G4, Rose Fall 2017 UW Tacoma, Team S1-G4, Rose Fall 2017 회원
UWT-ROSE-F17S1G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 13
전체 시간: 447
