주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ematic EGQ307 Battery Replacement
필요한 것
    1. Ematic EGQ307 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Ematic EGQ307 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
      댓글 쓰기
    2. Ematic EGQ307 Battery Replacement: 2 단계, 이미지 2개 중 1개 Ematic EGQ307 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
      • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
      댓글 쓰기
    3. Ematic EGQ307 Battery Replacement: 3 단계, 이미지 1개 중 1개
      • 3. Once you pry off the plastic backing, you will expose the battery.
      댓글 쓰기
    4. Ematic EGQ307 Battery Replacement: 4 단계, 이미지 3개 중 1개 Ematic EGQ307 Battery Replacement: 4 단계, 이미지 3개 중 2개 Ematic EGQ307 Battery Replacement: 4 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • 4. Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LED. Pry the battery off the LED using a plastic card.
      • Do not bend or warp the battery. Even though the battery may not be working, it is still dangerous.
      댓글 쓰기
    5. Ematic EGQ307 Battery Replacement: 5 단계, 이미지 1개 중 1개
      • If replacing the battery, unplug the black and red wires gently from the hardware and take off the battery .
      • If not replacing it, do not disconnect the red and black wires.
      • If replacing the battery, you will need a soldering kit to reconnect the wires with the new battery after disconnecting the old battery.
      • How To Solder and Desolder Connections.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Note, you need to solder the battery wires onto the motherboard.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Othman
회원 가입일: 07/21/15
267 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 36
전체 시간: 5,573
