주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ematic FunTab 2 Motherboard Replacement
필요한 것
    1. Ematic FunTab 2 Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
      • Remove back of Ematic FunTab by using the plastic opening tool to pry the back open.
      댓글 쓰기
    2. Ematic FunTab 2 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Ematic FunTab 2 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Ematic FunTab 2 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
      • Next, you need to remove all connections to the motherboard and the device.
      • Start by first removing the tape from all the connections.
      • Be careful not to remove the camera.
      댓글 쓰기
    3. Ematic FunTab 2 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Ematic FunTab 2 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Ematic FunTab 2 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
      • Remove LCD connector from the LCD.
      • Be sure to flip up the retaining tabs before pulling the LCD connector out. (It is the black tab on the connection port).
      댓글 쓰기
    4. Ematic FunTab 2 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Remove camera connection from camera with tweezers.
      • Again, be sure to flip up the retaining tab before pulling the connector.
      댓글 쓰기
    5. Ematic FunTab 2 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Remove speaker connection from speaker with tweezers.
      • Before pulling the speaker connection make sure the retaining tab is flipped up.
      댓글 쓰기
    6. Ematic FunTab 2 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Ematic FunTab 2 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Ematic FunTab 2 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
      • Remove wires:
      • Start by removing the black wire on each side.
      • Next, remove the WiFi antenna wire from the motherboard.
      • Finally, remove the yellow, red, and black wires.
      • To put the wires back in their correct locations you will need a soldering iron to solder the wire back in place. You will do this once the motherboard is replaced. Here is a guide on how to solder 연결부 납땜 및 납제거 방법
      댓글 쓰기
    7. Ematic FunTab 2 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Ematic FunTab 2 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Ematic FunTab 2 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
      • Unscrew all four screws on motherboard with the Phillip's head screwdriver.
      • All of the screws are the same size, and should all fit in either corresponding screw location.
      댓글 쓰기
    8. Ematic FunTab 2 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Ematic FunTab 2 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
      • It is now safe to remove and replace the old motherboard with your new motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Amanda Wolosz
회원 가입일: 04/05/15
287 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 36
전체 시간: 1,463
