주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ematic FunTab 3 Motherboard Replacement
필요한 것
  1. Ematic FunTab 3 Motherboard Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Ematic FunTab 3 Motherboard Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Ematic FunTab 3 Motherboard Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
    댓글 쓰기
  2. Ematic FunTab 3 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the back panel away from the screen.
    댓글 쓰기
  3. Ematic FunTab 3 Motherboard Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the black tape to reveal the wire ribbon connector.
    댓글 쓰기
  4. Ematic FunTab 3 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Ematic FunTab 3 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Ematic FunTab 3 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Flip up the black retaining tab using the plastic opening tool.
    • Pull out the large wire ribbon that crosses over the battery.
    • You may need tweezers to pull out the wire ribbon.
    댓글 쓰기
  5. Ematic FunTab 3 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Ematic FunTab 3 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Ematic FunTab 3 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool under the battery.
    • Using the plastic opening tool, pry up the battery.
    • There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
    댓글 쓰기
  6. Ematic FunTab 3 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Ematic FunTab 3 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
    • After the connections are desoldered, remove the battery.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
    댓글 쓰기
  7. Ematic FunTab 3 Motherboard Replacement, Speaker: 7 단계, 이미지 2개 중 1개 Ematic FunTab 3 Motherboard Replacement, Speaker: 7 단계, 이미지 2개 중 2개
    댓글 쓰기
  8. Ematic FunTab 3 Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Ematic FunTab 3 Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Ematic FunTab 3 Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • After the connections are desoldered, remove the speaker by prying it up using a plastic opening tool.
    • There is glue on the back of the speaker. Some more force may be required.
    댓글 쓰기
  9. Ematic FunTab 3 Motherboard Replacement, Camera: 9 단계, 이미지 2개 중 1개 Ematic FunTab 3 Motherboard Replacement, Camera: 9 단계, 이미지 2개 중 2개
    댓글 쓰기
  10. Ematic FunTab 3 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to flip up the black retaining tab.
    댓글 쓰기
  11. Ematic FunTab 3 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Ematic FunTab 3 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Pull out the wire ribbon connected to the camera.
    • The camera is held in place by glue, so extra force may be required.
    • Remove the camera from the device.
    댓글 쓰기
  12. Ematic FunTab 3 Motherboard Replacement, Motherboard: 12 단계, 이미지 1개 중 1개
    • Remove the black tape to reveal the screen connector.
    댓글 쓰기
  13. Ematic FunTab 3 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Ematic FunTab 3 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Flip up the retaining tab using the plastic opening tool.
    • Pull out the screen wire ribbon to disconnect the screen and motherboard.
    댓글 쓰기
  14. Ematic FunTab 3 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Ematic FunTab 3 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
    댓글 쓰기
  15. Ematic FunTab 3 Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • It is now safe to remove and replace the old motherboard with your new motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Amanda Davis
회원 가입일: 07/11/18
581 평판
안내서 5개를 작성함
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G5
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 28
전체 시간: 626
