주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ematic Genesis Screen Replacement
필요한 것
    1. Ematic Genesis Screen Replacement, Ematic Genesis Casing: 1 단계, 이미지 3개 중 1개 Ematic Genesis Screen Replacement, Ematic Genesis Casing: 1 단계, 이미지 3개 중 2개 Ematic Genesis Screen Replacement, Ematic Genesis Casing: 1 단계, 이미지 3개 중 3개
      • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
      댓글 쓰기
    2. Ematic Genesis Screen Replacement: 2 단계, 이미지 3개 중 1개 Ematic Genesis Screen Replacement: 2 단계, 이미지 3개 중 2개 Ematic Genesis Screen Replacement: 2 단계, 이미지 3개 중 3개
      • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
      • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
      • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
      • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
      댓글 쓰기
    3. Ematic Genesis Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Remove back plate from screen plate and lay both down flat next to each other.
      댓글 쓰기
    1. Ematic Genesis Screen Replacement, Battery: 4 단계, 이미지 3개 중 1개 Ematic Genesis Screen Replacement, Battery: 4 단계, 이미지 3개 중 2개 Ematic Genesis Screen Replacement, Battery: 4 단계, 이미지 3개 중 3개
      • Lift up the two pieces of tape holding the copper plate and the connector ribbon to the battery. Gently hold or place away from the battery.
      댓글 쓰기
    2. Ematic Genesis Screen Replacement: 5 단계, 이미지 3개 중 1개 Ematic Genesis Screen Replacement: 5 단계, 이미지 3개 중 2개 Ematic Genesis Screen Replacement: 5 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • Using a plastic card, gently break the adhesive that holds the battery to the metal screen plate.
      • The battery is very bendable. Although it may not be working, there are still dangerous contents inside batteries.
      댓글 쓰기
    3. Ematic Genesis Screen Replacement: 6 단계, 이미지 1개 중 1개
      • If replacing the battery, disconnect the wires that connect the battery to the motherboard.
      • If not replacing the battery, do NOT disconnect the wires.
      • To reconnect the new battery, a soldering kit will be necessary. Use the iFixit soldering guide to gain further information on how to complete this step.
      • 연결부 납땜 및 납제거 방법
      댓글 쓰기
    1. Ematic Genesis Screen Replacement, Camera: 7 단계, 이미지 2개 중 1개 Ematic Genesis Screen Replacement, Camera: 7 단계, 이미지 2개 중 2개
      • Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
      댓글 쓰기
    2. Ematic Genesis Screen Replacement: 8 단계, 이미지 2개 중 1개 Ematic Genesis Screen Replacement: 8 단계, 이미지 2개 중 2개
      • Lift up the black lever of the connector that holds the camera ribbon in place.
      댓글 쓰기
    3. Ematic Genesis Screen Replacement: 9 단계, 이미지 2개 중 1개 Ematic Genesis Screen Replacement: 9 단계, 이미지 2개 중 2개
      • Gently pull the ribbon out of the connector and lift the camera out of the casing.
      • There is adhesive holding the camera in the case. Pull up strong enough to separate the camera from the casing without damaging the components.
      댓글 쓰기
    1. Ematic Genesis Screen Replacement, Button: 10 단계, 이미지 3개 중 1개 Ematic Genesis Screen Replacement, Button: 10 단계, 이미지 3개 중 2개 Ematic Genesis Screen Replacement, Button: 10 단계, 이미지 3개 중 3개
      • Once battery is removed, flip up the black lever of the connector that is holding the wide ribbon in place for the screen. Remove the ribbon from the connector.
      댓글 쓰기
    2. Ematic Genesis Screen Replacement: 11 단계, 이미지 3개 중 1개 Ematic Genesis Screen Replacement: 11 단계, 이미지 3개 중 2개 Ematic Genesis Screen Replacement: 11 단계, 이미지 3개 중 3개
      • Rotate the tablet 180 degrees and flip up the black lever of the connector holding the small, yellow ribbon. Remove ribbon from the connector.
      댓글 쓰기
    3. Ematic Genesis Screen Replacement: 12 단계, 이미지 3개 중 1개 Ematic Genesis Screen Replacement: 12 단계, 이미지 3개 중 2개 Ematic Genesis Screen Replacement: 12 단계, 이미지 3개 중 3개
      • Rotate the tablet 90 degrees and remove the three (3) 1.3 mm Phillips #00 screws that hold the motherboard in place.
      댓글 쓰기
    4. Ematic Genesis Screen Replacement: 13 단계, 이미지 2개 중 1개 Ematic Genesis Screen Replacement: 13 단계, 이미지 2개 중 2개
      • Lift up the tape that covers the speaker wires and holds the motherboard in place.
      • This picture does not show speaker wires attached. These do NOT have to be disconnected for this.
      • Be careful not to disconnect the speaker wires from the motherboard. Otherwise, they will need to be soldered back on.
      댓글 쓰기
    5. Ematic Genesis Screen Replacement: 14 단계, 이미지 2개 중 1개 Ematic Genesis Screen Replacement: 14 단계, 이미지 2개 중 2개
      • With the motherboard detached from the screen plate, there is now access to the electrical components under the motherboard and the mechanical button components on the back plate.
      댓글 쓰기
    1. Ematic Genesis Screen Replacement, Screen: 15 단계, 이미지 2개 중 1개 Ematic Genesis Screen Replacement, Screen: 15 단계, 이미지 2개 중 2개
      • Once the battery and motherboard have been removed, gently bend the screen plate to pop out the metal digitizer that sits on the glass and plastic screen.
      • Be careful when bending as glass could break.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Justin Rohrman
회원 가입일: 03/23/15
745 평판
안내서 6개를 작성함
Baylor, Team 4-3, Williams Spring 2015 Baylor, Team 4-3, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G3
3 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 36
전체 시간: 1,501
