주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ematic eGlide 4 Motherboard Replacement
필요한 것
    1. Ematic eGlide 4 Motherboard Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
      • Remove the 4.6mm Phillips #00 screw at the base of the device.
      댓글 쓰기
    2. Ematic eGlide 4 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the rear panel away from the base parallel to the screen.
      댓글 쓰기
    3. Ematic eGlide 4 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Ematic eGlide 4 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
      • Carefully remove the speakers from the rear panel.
      • Pull the speakers off of the rear panel.
      댓글 쓰기
    1. Ematic eGlide 4 Motherboard Replacement, Speaker: 4 단계, 이미지 1개 중 1개
      댓글 쓰기
    1. Ematic eGlide 4 Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
      • Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger.
      • You do not need to fully disconnect the ribbon wire clip from the ribbon wire port: the clip will stay attached in a loose fit.
      • Remove the gold ribbon wire from the ribbon wire port on the motherboard.
      댓글 쓰기
    2. Ematic eGlide 4 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Slide the grey ribbon wire connector clip away from the white ribbon wire port on the screen board using the pointed tip of a spudger.
      • Remove the ribbon wire from the ribbon wire port on the screen board.
      댓글 쓰기
    3. Ematic eGlide 4 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
      • Slide the grey ribbon wire connector clip away from the ribbon wire port using the pointed tip of a spudger.
      • Remove the ribbon wire from the ribbon wire port.
      • If you have already removed the side button array you do not need to do this step.
      댓글 쓰기
    4. Ematic eGlide 4 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the 2 Phillips #00 4.5 mm screws from the motherboard.
      댓글 쓰기
    5. Ematic eGlide 4 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
      • Desolder the Wi-Fi Adaptor
      • If not replacing the motherboard or Wi-Fi Adaptor, omit this step
      • See ifixit's guide to soldering and desoldering for help: How to Solder and Desolder Connections
      댓글 쓰기
    6. Ematic eGlide 4 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
      • Desolder the battery connections
      • If not replacing the motherboard or battery, omit this step
      댓글 쓰기
    7. Ematic eGlide 4 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Ematic eGlide 4 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
      • Slide and pull the motherboard out of its current position, so that the ports disconnect from the device.
      • Lift the motherboard out of the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Bailey Hughes
회원 가입일: 03/22/15
617 평판
안내서 6개를 작성함
Baylor, Team 5-8, Williams Spring 2015 Baylor, Team 5-8, Williams Spring 2015 회원
BU-WILLIAMS-S15S5G8
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 24
전체 시간: 625
