Emson Star Wars R2-D2 Water Tank Valve Replacement
The valve allows water to move through the device in order for the water to be vaporized and ultimately emitted. If the device doesn't emit vapor or leaks, the water valve may not be functioning properly. It may also be possible that it isn't attached tightly enough. We will demonstrate the steps to take out the valve and then replace it.
다른 2명이 해당 안내서를 완성하였습니다.
