주요 콘텐츠로 건너뛰기
Etekcity Lasergrip 1080 Button Replacement
Patrick Crawford
Patrick Crawford9 다른 기여자
최종 수정일 October 5, 2017
3 분
조정
This guide will teach you how to replace buttons that are not functioning properly. This will use a screwdriver and a plastic opening tool. There are no hazards involved.
필요한 것
도구
  1. Etekcity Lasergrip 1080 Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Button Replacement: 2 단계, 이미지 1개 중 1개
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Button Replacement: 3 단계, 이미지 2개 중 1개 Etekcity Lasergrip 1080 Button Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Button Replacement, Buttons: 4 단계, 이미지 2개 중 1개 Etekcity Lasergrip 1080 Button Replacement, Buttons: 4 단계, 이미지 2개 중 2개
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Button Replacement: 5 단계, 이미지 2개 중 1개 Etekcity Lasergrip 1080 Button Replacement: 5 단계, 이미지 2개 중 2개
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Button Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Button Replacement: 7 단계, 이미지 2개 중 1개 Etekcity Lasergrip 1080 Button Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Button Replacement: 8 단계, 이미지 1개 중 1개
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
결론
작성자
9다른 기여자 명과 함께
Patrick Crawford
회원 가입일: 08/26/15
762 평판
안내서 6개를 작성함
USF Tampa, Team 5-1, Blackwell Fall 2015 USF Tampa, Team 5-1, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S5G1
3 회원들
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 6
지난 30일: 7
전체 시간: 517
