주요 콘텐츠로 건너뛰기
Etekcity Lasergrip 1080 Laser Replacement
Patrick Crawford
Patrick Crawford다른 한 명의 기여자
최종 수정일 November 4, 2015
5 분
조정
This will teach you to uninstall and reinstall a laser from the motherboard. This is needed if the laser stops working and cannot be turned on by pressing the button to do so. The tools required will be a screwdriver and a soldering iron. The soldering iron is hot and may cause a potential hazard. For those who are uncomfortable soldering, there is a link to a soldering guide in the Troubleshooting section of the device page.
필요한 것
도구
더보기...
  1. Etekcity Lasergrip 1080 Laser Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Laser Replacement: 2 단계, 이미지 1개 중 1개
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Laser Replacement: 3 단계, 이미지 2개 중 1개 Etekcity Lasergrip 1080 Laser Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Laser Replacement, Buttons: 4 단계, 이미지 2개 중 1개 Etekcity Lasergrip 1080 Laser Replacement, Buttons: 4 단계, 이미지 2개 중 2개
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Laser Replacement: 5 단계, 이미지 2개 중 1개 Etekcity Lasergrip 1080 Laser Replacement: 5 단계, 이미지 2개 중 2개
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Laser Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Laser Replacement: 7 단계, 이미지 2개 중 1개 Etekcity Lasergrip 1080 Laser Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Laser Replacement: 8 단계, 이미지 1개 중 1개
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Laser Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 9 단계, 이미지 2개 중 1개 Etekcity Lasergrip 1080 Laser Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Etekcity Lasergrip 1080 Laser Replacement, Laser: 10 단계, 이미지 1개 중 1개
    • Pull the motherboard out of its slot in the device.
  11. Etekcity Lasergrip 1080 Laser Replacement: 11 단계, 이미지 1개 중 1개
    • Use a soldering iron to melt the solder that holds the wires for the laser to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
결론
작성자
1다른 기여자 명과 함께
Patrick Crawford
회원 가입일: 08/26/15
762 평판
안내서 6개를 작성함
USF Tampa, Team 5-1, Blackwell Fall 2015 USF Tampa, Team 5-1, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S5G1
3 회원들
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 9
전체 시간: 996
