주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fahrenheit FHT 125PRMR Heating Plate Replacement
필요한 것
    1. Fahrenheit FHT 125PRMR Heating Plate Replacement, Heating Plate: 1 단계, 이미지 1개 중 1개
      • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
      댓글 쓰기
    2. Fahrenheit FHT 125PRMR Heating Plate Replacement: 2 단계, 이미지 1개 중 1개
      • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
      댓글 쓰기
    3. Fahrenheit FHT 125PRMR Heating Plate Replacement: 3 단계, 이미지 2개 중 1개 Fahrenheit FHT 125PRMR Heating Plate Replacement: 3 단계, 이미지 2개 중 2개
      • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
      • When the pin is removed the two sides of the device can now separate.
      • Be sure to collect the spring that is next to the hinge when they are separated.
      댓글 쓰기
    4. Fahrenheit FHT 125PRMR Heating Plate Replacement: 4 단계, 이미지 1개 중 1개
      • Using Philips head (PH1) remove the 6 mm black screw that was underneath the spring as well as the 6 mm black screw next to the heating plate. Remove the panel the screws were holding down.
      댓글 쓰기
    5. Fahrenheit FHT 125PRMR Heating Plate Replacement: 5 단계, 이미지 1개 중 1개
      • Using Philips head (PH1) remove the two 4 mm silver screws on the sides of dial panel cover
      댓글 쓰기
    6. Fahrenheit FHT 125PRMR Heating Plate Replacement: 6 단계, 이미지 2개 중 1개 Fahrenheit FHT 125PRMR Heating Plate Replacement: 6 단계, 이미지 2개 중 2개
      • Using Philips head (PH00) to remove the 4 mm silver screw on the dial. Remove the dial with your hand.
      댓글 쓰기
    7. Fahrenheit FHT 125PRMR Heating Plate Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the covering panel by pulling up with your hand.
      댓글 쓰기
    8. Fahrenheit FHT 125PRMR Heating Plate Replacement: 8 단계, 이미지 1개 중 1개
      댓글 쓰기
    9. Fahrenheit FHT 125PRMR Heating Plate Replacement: 9 단계, 이미지 2개 중 1개 Fahrenheit FHT 125PRMR Heating Plate Replacement: 9 단계, 이미지 2개 중 2개
      • Remove 3 sliver screws (3mm) (PH1) from the motherboard.
      댓글 쓰기
    10. Fahrenheit FHT 125PRMR Heating Plate Replacement: 10 단계, 이미지 1개 중 1개
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Omar El Mounayri
회원 가입일: 09/29/16
61 평판
안내서 1개를 작성함
IUPUI, Team 2-2, Harley Fall 2016 IUPUI, Team 2-2, Harley Fall 2016 회원
IUPUI-HARLEY-F16S2G2
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 30
전체 시간: 2,616
