주요 콘텐츠로 건너뛰기
Fan Blade Arm Replacement
Ricardo Ledesma Hernandez
Ricardo Ledesma Hernandez3 다른 기여자
최종 수정일 June 2, 2022
1 - 2 시간
쉬움
더 나은 이미지가 필요함
Use this guide to replace the broken blade arm of a ceiling fan. A broken ceiling fan can reduce the comfort of your home, and it might make you utilize your home’s air conditioner (AC) more. A working ceiling fan will save money and potentially reduce greenhouse gases that hurt the earth.
Before using this guide, make sure you know where the circuit breaker is located and turn it off for safety reasons. A few necessary tools are needed, and no prior knowledge is required.
  1. Fan Blade Arm Replacement, Fan Blade Arm: 1 단계, 이미지 3개 중 1개 Fan Blade Arm Replacement, Fan Blade Arm: 1 단계, 이미지 3개 중 2개 Fan Blade Arm Replacement, Fan Blade Arm: 1 단계, 이미지 3개 중 3개
    • Make sure no power is flowing to the fan. Then begin by removing the metal light frame by twisting.
  2. Fan Blade Arm Replacement: 2 단계, 이미지 2개 중 1개 Fan Blade Arm Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the finial (cover at the bottom of the glass globe). Then unscrew the hex nut and remove the rubber washer. This will allow the globe to be easily removed.
  3. Fan Blade Arm Replacement: 3 단계, 이미지 3개 중 1개 Fan Blade Arm Replacement: 3 단계, 이미지 3개 중 2개 Fan Blade Arm Replacement: 3 단계, 이미지 3개 중 3개
    • Remove lightbulbs to avoid damage when removing light pan. Then, remove all three fitter plate screws. This will cause the light pan to hang from the electrical wires.
  4. Fan Blade Arm Replacement: 4 단계, 이미지 2개 중 1개 Fan Blade Arm Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect single pin connectors to finish removing light fixture from fan.
  5. Fan Blade Arm Replacement: 5 단계, 이미지 2개 중 1개 Fan Blade Arm Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the three screws from the fitter plate. This will allow the plate to easily be separated from the fan.
  6. Fan Blade Arm Replacement: 6 단계, 이미지 3개 중 1개 Fan Blade Arm Replacement: 6 단계, 이미지 3개 중 2개 Fan Blade Arm Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two screws securing the broken blade arm. Then separate the broken component from the fan.
  7. Fan Blade Arm Replacement: 7 단계, 이미지 3개 중 1개 Fan Blade Arm Replacement: 7 단계, 이미지 3개 중 2개 Fan Blade Arm Replacement: 7 단계, 이미지 3개 중 3개
    • Replace the broken blade arm on the fan blade. There are two components that are placed on either side of the blade and secured together with screws.
    You forgot to mention where you magically bought that replacement piece for that particular ceiling fan!!!
    Brandy Broussard - 답글
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
회원 가입일: 10/29/19
145 평판
안내서 1개를 작성함
댓글 4개
Where did you bought the replacement for that specific fan I’m looking for the arm and blades with the star
Maria Franco - 답글
I am as well and harbor breeze and Lowe's are absolutely no help!
I’m looking for the same thing CANT find it anywhere I need the arm
Lisa - 답글
Where can I find an exact replacement.
Darrell Resler - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 23
지난 30일: 52
전체 시간: 8,175
