주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
First Act MA2039 Damaged Wire Replacement
필요한 것
    1. First Act MA2039 Damaged Wire Replacement, First Act MA2039 Damaged Wire Replacement: 1 단계, 이미지 2개 중 1개 First Act MA2039 Damaged Wire Replacement, First Act MA2039 Damaged Wire Replacement: 1 단계, 이미지 2개 중 2개
      • Place the speaker with its front side facing down.
      • Use a Phillips #0 screwdriver to remove the two 25 mm screws from the left and right sides of the battery cartridges.
      • Open both lids to the battery cartridges.
      댓글 쓰기
    2. First Act MA2039 Damaged Wire Replacement: 2 단계, 이미지 3개 중 1개 First Act MA2039 Damaged Wire Replacement: 2 단계, 이미지 3개 중 2개 First Act MA2039 Damaged Wire Replacement: 2 단계, 이미지 3개 중 3개
      • As you begin to lift the back panel off the amplifier, push the battery terminals through the open slots of the battery cartridges.
      • Use your fingers to prop the back panel and lift it away from the amplifier.
      • Lift the back panel off completely and set it to the side.
      댓글 쓰기
    3. First Act MA2039 Damaged Wire Replacement: 3 단계, 이미지 3개 중 1개 First Act MA2039 Damaged Wire Replacement: 3 단계, 이미지 3개 중 2개 First Act MA2039 Damaged Wire Replacement: 3 단계, 이미지 3개 중 3개
      • With the back panel off, this will help make space for the silver compartment to be removed.
      • Unscrew four 25 mm screws with a Phillips #0 screwdriver from the top of the amplifier.
      • Press firmly on the input jack and tone adjustment knob of the silver compartment to free it from its resting position.
      댓글 쓰기
    4. First Act MA2039 Damaged Wire Replacement: 4 단계, 이미지 3개 중 1개 First Act MA2039 Damaged Wire Replacement: 4 단계, 이미지 3개 중 2개 First Act MA2039 Damaged Wire Replacement: 4 단계, 이미지 3개 중 3개
      • Rotate the silver compartment so that you have a clear visual of the motherboard and its components.
      • For effective work on the wiring, lodge the compartment on top of the back portion of the amplifier.
      • Check the wiring components for blown fuses or damaged connections.
      댓글 쓰기
    5. First Act MA2039 Damaged Wire Replacement: 5 단계, 이미지 1개 중 1개
      • Lift the silver compartment to see where the wires are further connected.
      • Make sure that the terminals from the circuit to the amplifier are connected securely.
      • Check to see if there is loose wiring from the motherboard.
      • If there is damaged wire to the amplifier or motherboard in the silver compartment, refer this Soldering guide to replace wires and fix connections.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Luke VanBuskirk
회원 가입일: 04/05/18
279 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 31
전체 시간: 716
