주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fitbit Blaze Battery Replacement
필요한 것
    1. Fitbit Blaze Battery Replacement, Wristband: 1 단계, 이미지 2개 중 1개 Fitbit Blaze Battery Replacement, Wristband: 1 단계, 이미지 2개 중 2개
      • Locate the front LCD screen on your device.
      • Fitbit logo should appear in the bottom center of the screen.
      댓글 쓰기
    2. Fitbit Blaze Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Push the screen out through the back of the metal ring enclosure.
      • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
      댓글 쓰기
    3. Fitbit Blaze Battery Replacement: 3 단계, 이미지 3개 중 1개 Fitbit Blaze Battery Replacement: 3 단계, 이미지 3개 중 2개 Fitbit Blaze Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Locate the metal pin behind the wristband located on the edge of metal ring.
      • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
      • Use a small amount of force to avoid damaging the pins.
      • Remove wristband.
      댓글 쓰기
    1. Fitbit Blaze Battery Replacement, Battery: 4 단계, 이미지 3개 중 1개 Fitbit Blaze Battery Replacement, Battery: 4 단계, 이미지 3개 중 2개 Fitbit Blaze Battery Replacement, Battery: 4 단계, 이미지 3개 중 3개
      • Place device screen face down and locate the four screws attaching the back cover.
      • Use a T3 torx head or T3 torx screwdriver to remove the four screws.
      댓글 쓰기
    2. Fitbit Blaze Battery Replacement: 5 단계, 이미지 3개 중 1개 Fitbit Blaze Battery Replacement: 5 단계, 이미지 3개 중 2개 Fitbit Blaze Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Grab the back, lift and open like a book to expose the motherboard. Locate the ribbon connector on the left.
      • Use a plastic spudger tool on the ribbon connected from the heart rate monitor to the motherboard.
      • Insert and lift the plastic opening tool to release the ribbon.
      • Only a small force when lifting the plastic connector is needed to avoid damage.
      댓글 쓰기
    3. Fitbit Blaze Battery Replacement: 6 단계, 이미지 3개 중 1개 Fitbit Blaze Battery Replacement: 6 단계, 이미지 3개 중 2개 Fitbit Blaze Battery Replacement: 6 단계, 이미지 3개 중 3개
      • Separate the back and set aside, locate the three screws attaching the motherboard.
      • Use a PH000 head or a PH000 screwdriver to remove the three screws.
      댓글 쓰기
    4. Fitbit Blaze Battery Replacement: 7 단계, 이미지 3개 중 1개 Fitbit Blaze Battery Replacement: 7 단계, 이미지 3개 중 2개 Fitbit Blaze Battery Replacement: 7 단계, 이미지 3개 중 3개
      • Use a plastic spudger tool on the ribbons connected to the motherboard.
      • Insert the tool under the ribbon and lift to release the connection.
      댓글 쓰기
    5. Fitbit Blaze Battery Replacement: 8 단계, 이미지 3개 중 1개 Fitbit Blaze Battery Replacement: 8 단계, 이미지 3개 중 2개 Fitbit Blaze Battery Replacement: 8 단계, 이미지 3개 중 3개
      • Lift and push the motherboard to the side to uncover the 167mAh battery.
      • Use a plastic spudger tool to pry out the battery from its adhesive plastic underneath.
      • Lift up and pull downward to remove battery. Switch to the top portion of the battery and push downward to pry out battery.
      댓글 쓰기
    6. Fitbit Blaze Battery Replacement: 9 단계, 이미지 3개 중 1개 Fitbit Blaze Battery Replacement: 9 단계, 이미지 3개 중 2개 Fitbit Blaze Battery Replacement: 9 단계, 이미지 3개 중 3개
      • Flip the motherboard backwards and locate the metal pins from the battery soldered to the board.
      • Desolder the connection to remove the battery, desolder the battery connector itself if desired as well.
      • Follow this guide on how to solder and desolder connectors Soldering Guide
      • Excessive heat will damage the components, so do not apply the soldering iron to the component for long amounts of time.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 62명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Adrian Borrego
회원 가입일: 02/20/17
2,242 평판
안내서 5개를 작성함
USF Tampa, Team S3-G3, Sullivan Spring 2017 USF Tampa, Team S3-G3, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S3G3
4 회원들
안내서 20개를 작성함
55가이드 댓글
Where can I buy this battery?
Please contact fred@doble.com.br
Frederico Araujo - 답글 공유
no answer for:
Pierre Therien - 답글 공유
Looking for this battery as well; mine lasted exactly 1 year. 7 days now down to hours, the surge did the same thing, maybe my last Fitbit watch ever! Disappointed to say the least.
Darrell Way - 답글 공유
I found a battery, 3.7 volt at 165mAh in the same style, should be close enough but I do not have the size of the factory battery, if anyone has taken theirs apart, can you post up the measurements in mm? thanks
Darrell Way - 답글 공유
I can't find the battery anywhere either. Would love some advice. Tried Amazon, AliExpress, eBay and Google in general.
Chris Wilson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 22
지난 30일: 97
전체 시간: 135,762
