주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fix unstable bluetooth connection
필요한 것
    1. Fix unstable bluetooth connection, Heating up the lid: 1 단계, 이미지 1개 중 1개
      • Heat up the lid by leaving the earbud upside down on a hotplate at ~80°C for ~1min. A 3d printers hotbed works well for this.
      • A heat gun should also work as well.
      댓글 쓰기
    2. Fix unstable bluetooth connection, Breaking the seal: 2 단계, 이미지 1개 중 1개
      • The earbuds are glued shut.
      • Put some cloth around the earbud and put it in a vice like shown.
      • Pliers might work too if you don't have a vice but it's not recommended.
      • Slowly close the vice until there is a cracking sound or a gap forms in the seam.
      댓글 쓰기
    3. Fix unstable bluetooth connection, Removing the lid: 3 단계, 이미지 1개 중 1개
      • Heat up the lid again before continuing.
      • Separate the 2 halfs using one of the opening picks.
      • Make sure not to press the pick more then ~1mm into the case to avoid damaging anything on the PCB.
      • Slowly lift up the outer half after cracking the seal around the whole earbud. Slowly pull them apart as there is some flexible adhesive on 2 internal pegs that takes a bit of time to "give up".
      댓글 쓰기
    4. Fix unstable bluetooth connection, Secure the mic cover: 4 단계, 이미지 1개 중 1개
      • The marked mic cover tends to easily get lost. It's best to take it of and store it with the top half until reassembly.
      댓글 쓰기
    5. Fix unstable bluetooth connection, Scrape away old glue: 5 단계, 이미지 1개 중 1개
      • Try to remove as much of the hard, clear glue on the outside edge to make sure the buds close nicely when reassembling them.
      • A precision rotary tool with a fine abrasive tip and/or a scalpel works best.
      댓글 쓰기
    6. Fix unstable bluetooth connection, Remove old glue: 6 단계, 이미지 1개 중 1개
      • Try to remove as much of the white glue as possible using a scalpel and/or tweezers.
      • Putting the lid back on the hotplate or a bit of Isopropanol can help softening it.
      댓글 쓰기
    7. 댓글 쓰기
    1. Fix unstable bluetooth connection, Lift antenna: 8 단계, 이미지 2개 중 1개 Fix unstable bluetooth connection, Lift antenna: 8 단계, 이미지 2개 중 2개
      • Lift up the contact area of the antenna with a scalpel.
      • Be especially careful when pushing it around the mic port(marked in red) that's beneath it.
      댓글 쓰기
    2. Fix unstable bluetooth connection, Add piece of foam: 9 단계, 이미지 1개 중 1개
      • Put a thin piece of foam the size of the contact area behind it.
      댓글 쓰기
    3. Fix unstable bluetooth connection, Push the antenna back in place: 10 단계, 이미지 1개 중 1개
      • Fold the contact are back down.
      댓글 쓰기
작성자
1다른 기여자 명과 함께
Byte Hoarder
회원 가입일: 07/03/25
535 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 38
전체 시간: 408
