주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Flip MinoHD Battery Replacement
필요한 것
    1. Flip MinoHD Battery Replacement, Casing: 1 단계, 이미지 2개 중 1개 Flip MinoHD Battery Replacement, Casing: 1 단계, 이미지 2개 중 2개
      • With the plastic opening tool, remove labels from the Flip Mino HD. 2 small black screws should appear.
      • With the Phillips Screwdriver 000, unscrew the 2 screws and set aside in a safe place.
      댓글 쓰기
    2. Flip MinoHD Battery Replacement: 2 단계, 이미지 2개 중 1개 Flip MinoHD Battery Replacement: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting.
      • Do not pull to remove the casing until all sides are loose. You may break or crack the case.
      • Once case is loose, flip up and over the device. Note that casing is still connected to the device.
      • Using tweezers, pull connecting strip to disconnect it from its socket on the logic board.
      댓글 쓰기
    1. Flip MinoHD Battery Replacement, Motherboard: 3 단계, 이미지 3개 중 1개 Flip MinoHD Battery Replacement, Motherboard: 3 단계, 이미지 3개 중 2개 Flip MinoHD Battery Replacement, Motherboard: 3 단계, 이미지 3개 중 3개
      • With plastic opening tool, take the display screen out of its socket by gently lifting each corner. Flip the screen up towards the Motherboard that it is still connected to.
      • The screen is still connected.
      • Using the spudger, gently lift the film underneath the display bracket to peel it off. Set aside.
      • With the plastic opening tool, gently pry open metal display bracket to remove from the Motherboard.
      • Using fingernail, pry black tape up from zif socket to remove the partially attached display screen.
      댓글 쓰기
    2. Flip MinoHD Battery Replacement: 4 단계, 이미지 3개 중 1개 Flip MinoHD Battery Replacement: 4 단계, 이미지 3개 중 2개 Flip MinoHD Battery Replacement: 4 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • With the Phillips screwdriver 000 unscrew the 4 screws attaching the Motherboard to its outer casing and place safely aside.
      • Set up soldering station. At station, de-solder the leads of both microphones from the Motherboard.
      • This step can be done without a soldering station, using only tweezers and fingers. Just be extremely cautious!
      • With tweezers, gently pull the lead away as you heat up the joint with the tip of the iron. Do this for all 4 microphone leads.
      • Gently pry the Motherboard out of its case, minding that the cords are still connecting the case and Motherboard. Remove the small black piece of tape that is securing the USB cable to the battery.
      • With tweezers, pull the USB ribbon cable connector away from its socket. Pull battery connector out of its socket on the logic board. The Motherboard should now be loose and free to remove.
      댓글 쓰기
    1. Flip MinoHD Battery Replacement, Battery: 5 단계, 이미지 2개 중 1개 Flip MinoHD Battery Replacement, Battery: 5 단계, 이미지 2개 중 2개
      • With the Phillips screwdriver 000, unscrew the two small screws securing the battery to the outer case and set safely aside.
      • With the plastic opening tool, pry the battery out of device and set aside. Now the battery is fully removed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Abigail Buckenberger
회원 가입일: 01/06/16
732 평판
안내서 5개를 작성함
5가이드 댓글
Hello ! I want to ask a question that my flip mino hd turns on properly but when i press the recording button to record video my flip mino hd turns off suddenly..and it also recharges normally...please help me ..if any one has a solution must tell me!
saif - 답글 공유
Hello Saif, Did ever get your question answered to your satisfaction? I currently have the exact same problem you described in your post!
Thank you! Chris
ccc 124 - 답글 공유
In Step 3, the 2nd photo is wrong - it's the same as the 2nd photo in Step 2!
In the 2nd bullet, the black film should remain attached to the back of the screen, not the metal plate beneath.
In the 3rd bullet it's not very clear how the metal plate is meant to be released. It's secured by 3 plastic clips which I think are supposed to just pull off though one on mine has broken in the process. Some more double sided tape underneath the plate doesn't help.
Philip Le Riche - 답글 공유
Thank you for the guide! I used this to fix my Flip MinoHD 3rd Generation model. The model pictured in these instructions appears to be the 2nd Generation model, so everyone PLEASE NOTE this before proceeding with your repair. Here is some feedback after we completed these instructions:
1. Says the process should take 15 minutes. It takes MUCH longer than that (around 2 hours for us).
2. If you're going to use a #000 Phillips screwdriver, make sure it has a really good grip. The screws on this camera were in there super tight.
3. An extra pair of hands helps!
4. There's a part in the article that talks about de-soldering wires. You do NOT have to do this. Just be very careful!
5. You WILL need electrical tape to stick the new battery into the metal housing that holds the battery in the camera.
6. You need very flat tweezers for this, so we used eyebrow tweezers to handle the ribbon cables. Pocket knife tweezers are NOT recommended.
Hope this feedback helps!
Sam Lisker - 답글 공유
I was successful with the disassembly, battery replacement and reassembly up to where I reassembled the circuit board. Here I discovered that the thin red cable on the upper left hand corner of the board was only attached on top and not on the bottom. From another battery replacement video I can see that the other end of that cable is attached somewhere on the underside of the board. However, I cannot determine exactly where that end was attached (i.e. no evidence of a solder connection). Can anyone identify where and how that is to be reconnected.
WAYNE SEDEN - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 35
지난 30일: 177
전체 시간: 23,729
