주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Framework Desktop Primary Storage Replacement
필요한 것
  1. Framework Desktop Primary Storage Replacement, Power down your Desktop: 1 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement, Power down your Desktop: 1 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement, Power down your Desktop: 1 단계, 이미지 3개 중 3개
    • Before you begin repairs, shut down your Desktop from the operating system and unplug it.
    • Wait one minute before continuing to allow your Desktop to fully power down.
    • Make sure your Framework Desktop Screwdriver has the T5 Torx bit (labeled as T5) facing outwards. If it's not, pull the bit out and flip it.
    댓글 쓰기
  2. Framework Desktop Primary Storage Replacement, Remove the Handle: 2 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement, Remove the Handle: 2 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement, Remove the Handle: 2 단계, 이미지 3개 중 3개
    • If you installed the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
    • Remove the Handle.
    댓글 쓰기
  3. Framework Desktop Primary Storage Replacement, Remove the Top Panel screws: 3 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement, Remove the Top Panel screws: 3 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement, Remove the Top Panel screws: 3 단계, 이미지 3개 중 3개
    • Use your finger to lift up the two D-rings on the Top Panel screws.
    댓글 쓰기
  4. Framework Desktop Primary Storage Replacement: 4 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement: 4 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement: 4 단계, 이미지 3개 중 3개
    • Use your fingers to twist the screw counter-clockwise and loosen it.
    • Remove the Top Panel screw.
    댓글 쓰기
  5. Framework Desktop Primary Storage Replacement: 5 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement: 5 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement: 5 단계, 이미지 3개 중 3개
    • Repeat the same procedure for the other Top Panel screw.
    댓글 쓰기
  6. Framework Desktop Primary Storage Replacement, Remove the Top Panel: 6 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement, Remove the Top Panel: 6 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement, Remove the Top Panel: 6 단계, 이미지 3개 중 3개
    • Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
    • If you're having a hard time gripping the Top Panel, use the screw holes to get a better handhold.
    • Lift the Top Panel off the chassis and remove it.
    댓글 쓰기
  7. Framework Desktop Primary Storage Replacement, Remove the Left Panel: 7 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement, Remove the Left Panel: 7 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement, Remove the Left Panel: 7 단계, 이미지 3개 중 3개
    • Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
    • Remove the Left Panel.
    댓글 쓰기
  8. Framework Desktop Primary Storage Replacement, Loosen the SSD screw: 8 단계, 이미지 2개 중 1개 Framework Desktop Primary Storage Replacement, Loosen the SSD screw: 8 단계, 이미지 2개 중 2개
    • Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the SSD.
    • The SSD and its heat spreader will pop up to an angle when its screw is fully loosened.
    댓글 쓰기
  9. Framework Desktop Primary Storage Replacement, Remove the SSD: 9 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement, Remove the SSD: 9 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement, Remove the SSD: 9 단계, 이미지 3개 중 3개
    • While holding the heat spreader upright, grab the SSD by its edges and pull it out of its socket.
    • Remove the SSD.
    댓글 쓰기
  10. Framework Desktop Primary Storage Replacement, Remove the primary storage heat spreader screw: 10 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement, Remove the primary storage heat spreader screw: 10 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement, Remove the primary storage heat spreader screw: 10 단계, 이미지 3개 중 3개
    • If your replacement SSD comes with a pre-installed heat spreader, follow the next two steps. Otherwise skip here.
    • While securing the primary storage heat spreader with one hand, use your Framework Desktop Screwdriver to remove the 4.5 mm‑long T5 Torx screw securing it.
    댓글 쓰기
  11. Framework Desktop Primary Storage Replacement, Remove the primary storage heat spreader: 11 단계, 이미지 1개 중 1개
    • Lift the primary storage heat spreader out of the Desktop and remove it.
    • Follow the guide normally, making sure to ignore instructions that involve the primary storage heat spreader.
    댓글 쓰기
  12. Framework Desktop Primary Storage Replacement, Disassembly complete: 12 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
    댓글 쓰기
  13. Framework Desktop Primary Storage Replacement, Loosen the heat spreader screw: 13 단계, 이미지 1개 중 1개
    댓글 쓰기
  14. Framework Desktop Primary Storage Replacement, Install the SSD: 14 단계, 이미지 2개 중 1개 Framework Desktop Primary Storage Replacement, Install the SSD: 14 단계, 이미지 2개 중 2개
    • Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • While holding the heat spreader upright, align the SSD's gold contacts with its socket.
    • Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • The SSD fits into the socket in one orientation. If it doesn't feel like it fits, try flipping the module.
    댓글 쓰기
  15. Framework Desktop Primary Storage Replacement, Install the SSD screw: 15 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement, Install the SSD screw: 15 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement, Install the SSD screw: 15 단계, 이미지 3개 중 3개
    • Insert your Framework Desktop Screwdriver into the captive screw on the primary storage heat spreader and press it flat to the Mainboard.
    • Tighten the screw securing the SSD.
    댓글 쓰기
  16. Framework Desktop Primary Storage Replacement, Install the Left Panel: 16 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement, Install the Left Panel: 16 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement, Install the Left Panel: 16 단계, 이미지 3개 중 3개
    • Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
    • There should be a small gap between the bottom of the Left Panel and the silver base.
    • Push the Left Panel towards the base of the computer to close the gap and engage the clips.
    댓글 쓰기
  17. Framework Desktop Primary Storage Replacement, Install the Top Panel: 17 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement, Install the Top Panel: 17 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement, Install the Top Panel: 17 단계, 이미지 3개 중 3개
    • Orient the Top Panel so its arrow is pointing towards the rear of the computer.
    • While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
    • There should be a small gap between the Top Panel and the front of the Desktop.
    • Lay the Top Panel flat on the chassis to align the remaining clips.
    댓글 쓰기
  18. Framework Desktop Primary Storage Replacement: 18 단계, 이미지 2개 중 1개 Framework Desktop Primary Storage Replacement: 18 단계, 이미지 2개 중 2개
    • While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
    댓글 쓰기
  19. Framework Desktop Primary Storage Replacement, Install the Handle: 19 단계, 이미지 2개 중 1개 Framework Desktop Primary Storage Replacement, Install the Handle: 19 단계, 이미지 2개 중 2개
    • If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Place the Handle over the Top Panel screw holes.
    • While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
    댓글 쓰기
  20. Framework Desktop Primary Storage Replacement, Install the top panel screws: 20 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement, Install the top panel screws: 20 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement, Install the top panel screws: 20 단계, 이미지 3개 중 3개
    • Insert the top panel screw into its hole and twist clockwise until it feels snug.
    댓글 쓰기
  21. Framework Desktop Primary Storage Replacement: 21 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement: 21 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement: 21 단계, 이미지 3개 중 3개
    • Repeat the same procedure for the other top panel screw.
    댓글 쓰기
  22. Framework Desktop Primary Storage Replacement: 22 단계, 이미지 3개 중 1개 Framework Desktop Primary Storage Replacement: 22 단계, 이미지 3개 중 2개 Framework Desktop Primary Storage Replacement: 22 단계, 이미지 3개 중 3개
    • Use your finger to close the two D-rings on the top panel screws.
    댓글 쓰기
결론
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
244,959 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 58
전체 시간: 1,034
