주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Framework Laptop 12 Storage Replacement
필요한 것
  1. Framework Laptop 12 Storage Replacement, Power down your laptop: 1 단계, 이미지 3개 중 1개 Framework Laptop 12 Storage Replacement, Power down your laptop: 1 단계, 이미지 3개 중 2개 Framework Laptop 12 Storage Replacement, Power down your laptop: 1 단계, 이미지 3개 중 3개
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
    댓글 쓰기
  2. Framework Laptop 12 Storage Replacement, Set your laptop down: 2 단계, 이미지 1개 중 1개
    • Set your Framework Laptop face-down on a clean work surface.
    댓글 쓰기
  3. Framework Laptop 12 Storage Replacement, Loosen the bottom screws: 3 단계, 이미지 2개 중 1개 Framework Laptop 12 Storage Replacement, Loosen the bottom screws: 3 단계, 이미지 2개 중 2개
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    댓글 쓰기
  4. Framework Laptop 12 Storage Replacement, Flip your laptop over: 4 단계, 이미지 1개 중 1개
    • Flip your laptop over so it's face-up on your work surface.
    댓글 쓰기
  5. Framework Laptop 12 Storage Replacement, Open your laptop: 5 단계, 이미지 2개 중 1개 Framework Laptop 12 Storage Replacement, Open your laptop: 5 단계, 이미지 2개 중 2개
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
    댓글 쓰기
  6. Framework Laptop 12 Storage Replacement, Remove the Input Cover: 6 단계, 이미지 3개 중 1개 Framework Laptop 12 Storage Replacement, Remove the Input Cover: 6 단계, 이미지 3개 중 2개 Framework Laptop 12 Storage Replacement, Remove the Input Cover: 6 단계, 이미지 3개 중 3개
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
    댓글 쓰기
  7. Framework Laptop 12 Storage Replacement, Unlatch the SSD: 7 단계, 이미지 2개 중 1개 Framework Laptop 12 Storage Replacement, Unlatch the SSD: 7 단계, 이미지 2개 중 2개
    • Use your finger to press down on the black SSD latch to unlatch the SSD.
    • The SSD will pop up to an angle when it's unlatched.
    댓글 쓰기
  8. Framework Laptop 12 Storage Replacement, Remove the SSD: 8 단계, 이미지 3개 중 1개 Framework Laptop 12 Storage Replacement, Remove the SSD: 8 단계, 이미지 3개 중 2개 Framework Laptop 12 Storage Replacement, Remove the SSD: 8 단계, 이미지 3개 중 3개
    • Grab the SSD by its edges and pull it out of its socket.
    • Remove the SSD.
    댓글 쓰기
  9. Framework Laptop 12 Storage Replacement, Disassembly complete: 9 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
    댓글 쓰기
  10. Framework Laptop 12 Storage Replacement, Install the SSD: 10 단계, 이미지 2개 중 1개 Framework Laptop 12 Storage Replacement, Install the SSD: 10 단계, 이미지 2개 중 2개
    • Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • Align the SSD's gold contacts with its socket.
    • Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • The SSD fits into the socket in one orientation. If it doesn't feel like it fits, try flipping the module.
    댓글 쓰기
  11. Framework Laptop 12 Storage Replacement: 11 단계, 이미지 3개 중 1개 Framework Laptop 12 Storage Replacement: 11 단계, 이미지 3개 중 2개 Framework Laptop 12 Storage Replacement: 11 단계, 이미지 3개 중 3개
    • Use your finger to press down on the black SSD latch to keep it open.
    • Use another finger to press the SSD down until it lays flat.
    • If the SSD doesn't fit in the latch, you may need to insert the SSD further into its socket.
    • Use your finger to close the latch to secure the SSD.
    • You should hear a click, and the SSD should no longer pop up.
    댓글 쓰기
  12. Framework Laptop 12 Storage Replacement, Install the Input Cover: 12 단계, 이미지 3개 중 1개 Framework Laptop 12 Storage Replacement, Install the Input Cover: 12 단계, 이미지 3개 중 2개 Framework Laptop 12 Storage Replacement, Install the Input Cover: 12 단계, 이미지 3개 중 3개
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
    • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
    • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
    댓글 쓰기
  13. Framework Laptop 12 Storage Replacement, Close and flip your laptop: 13 단계, 이미지 2개 중 1개 Framework Laptop 12 Storage Replacement, Close and flip your laptop: 13 단계, 이미지 2개 중 2개
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
    댓글 쓰기
  14. Framework Laptop 12 Storage Replacement, Tighten the bottom screws: 14 단계, 이미지 2개 중 1개 Framework Laptop 12 Storage Replacement, Tighten the bottom screws: 14 단계, 이미지 2개 중 2개
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
    댓글 쓰기
결론
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
343,753 평판
안내서 915개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 19,791개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 53
전체 시간: 837
