주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fugoo Style XL Battery Replacement
필요한 것
    1. Fugoo Style XL Battery Replacement, Fabric Case: 1 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement, Fabric Case: 1 단계, 이미지 2개 중 2개
      • Using your hand, unscrew the large screws underneath the speaker.
      댓글 쓰기
    2. Fugoo Style XL Battery Replacement: 2 단계, 이미지 3개 중 1개 Fugoo Style XL Battery Replacement: 2 단계, 이미지 3개 중 2개 Fugoo Style XL Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Using your hand, gently lift the large plastic tab secured to the rubber holding.
      • After lifting the tab, slide the speaker out of its case.
      • Ensure the tab is lifted only slightly above the rubber holding. Bending the plastic tab too far could result in damage to the case.
      댓글 쓰기
    1. Fugoo Style XL Battery Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
      • Remove the 8 screws (4 on each side) that hold the covers that conceal the bass speakers. Remove these 3mm screws using a #2.0 Hex screwdriver.
      댓글 쓰기
    2. Fugoo Style XL Battery Replacement: 4 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Using your hand, pull the covers away from the speaker.
      댓글 쓰기
    3. Fugoo Style XL Battery Replacement: 5 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Use a #2.0 Hex screwdriver to unscrew the 8 screws shown in the image.
      댓글 쓰기
    4. Fugoo Style XL Battery Replacement: 6 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Gently pull apart the front casing from the back casing.
      • Speakers on the front casing have wires directly connected to the motherboard. Pulling off the casing with force will result in damage.
      댓글 쓰기
    5. Fugoo Style XL Battery Replacement: 7 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement: 7 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using a pair of tweezers or your hand, carefully remove the red bundled cable connectors from the motherboard.
      • When the red bundled cable connectors are disconnected, set the outer casing aside.
      댓글 쓰기
    6. Fugoo Style XL Battery Replacement: 8 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement: 8 단계, 이미지 2개 중 2개
      • Untangle any blue bundled cable connectors and gently remove them from the motherboard using a pair of tweezers.
      댓글 쓰기
    7. Fugoo Style XL Battery Replacement: 9 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement: 9 단계, 이미지 2개 중 2개
      • Carefully untangle and remove the white bundled cable connectors from the motherboard.
      댓글 쓰기
    8. Fugoo Style XL Battery Replacement: 10 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement: 10 단계, 이미지 2개 중 2개
      • Using a T9 screwdriver, remove the 8 screws (4 on each speaker) surrounding the midwoofers.
      • Using your hand, carefully remove the midwoofers.
      댓글 쓰기
    9. Fugoo Style XL Battery Replacement: 11 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement: 11 단계, 이미지 2개 중 2개
      • Using a pair of tweezers, lift the padded holding that secures the ZIF connector to the motherboard. The connector will release from the motherboard once the padding is lifted.
      • Do not pull on the cables themselves. Doing so can damage the cables. Always remove the ZIF connector by gently lifting the padding securing them to the motherboard.
      댓글 쓰기
    10. Fugoo Style XL Battery Replacement: 12 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement: 12 단계, 이미지 2개 중 2개
      • Carefully lift the battery and motherboard unit halfway out of the casing. The motherboard is connected to the battery directly.
      • There is a small coaxial cable connected underneath the motherboard. Using a pair of tweezers, carefully disconnect and remove the cable from under the adhesive tape.
      • When the cable is disconnected, fully remove the motherboard and battery unit.
      댓글 쓰기
    11. Fugoo Style XL Battery Replacement: 13 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement: 13 단계, 이미지 2개 중 2개
      • Remove the 3mm screws using a #2.0 Hex screwdriver. There are 4 of these screws (2 on each side) that connect the motherboard to the battery unit.
      • When the screws are removed, use an iFixit opening tool to remove the motherboard from the two clamps securing it to the battery pack.
      • Beware! The motherboard is not fully disconnected from the battery even when removed from the clamps.
      댓글 쓰기
    12. Fugoo Style XL Battery Replacement: 14 단계, 이미지 2개 중 1개 Fugoo Style XL Battery Replacement: 14 단계, 이미지 2개 중 2개
      • Using tweezers or your hand, carefully disconnect the bundled cables connecting the battery to the motherboard.
      댓글 쓰기
    1. Fugoo Style XL Battery Replacement, Battery: 15 단계, 이미지 1개 중 1개
      • Separate the motherboard from the battery to access and replace the battery.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
James Gifford
회원 가입일: 09/25/17
573 평판
안내서 5개를 작성함
USF Tampa, Team S3-G4, Cannon Fall 2017 USF Tampa, Team S3-G4, Cannon Fall 2017 회원
USFT-CANNON-F17S3G4
4 회원들
안내서 10개를 작성함
6가이드 댓글
Where can I purchase a replacement battery?
Vincent walcott - 답글 공유
Thanks, it was clear and very help full, fortunately for me it was a solder defect on battery PCB, I just refresh the solder joint with new solder and the speaker works perfectly.
Luis Alberto Gonzalez Lopez - 답글 공유
Also I found in Ebay some batteries replacement of 3.7V and 3000mah, but you will need to assembly the battery pack , that will need some electronic knowledge, but I think is not really hard to do.
This guide is very helpful, but does not state which type of batteries are required. Please state which type of battery (or batteries) would suit as a replacement. Thank you!
william.start - 답글 공유
Extremely useful repair steps. Really appreciate your meticulous nature. Thanks!
josefasoh - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 77
전체 시간: 6,299
