주요 콘텐츠로 건너뛰기
Fujitsu Lifebook E546 RAM Modules Replacement
Michał Kurda
Michał Kurda다른 한 명의 기여자
최종 수정일 July 22, 2023
5 분
매우 쉬움
커뮤니티-기여 안내서
Hello!
In this guide I will show you how to replace RAM module/stick in Fujitsu Lifebook laptop, model E546. It is very easy. However, if you're doing this for the first time, simply take your time. I don't take any responsibility for any damage done by yourself!
I recommend to keep your screw and parts organized - it helps with reassembling and lowers risk of missing screws!
필요한 것
도구
  1. Fujitsu Lifebook E546 RAM Modules Replacement, Removing battery: 1 단계, 이미지 1개 중 1개
    • Before doing something, always remove the battery!
    • First, gently pull down and hold that little tab down (1) to unlock the second tab.
    • Then move left the second tab (2). Both tabs should be secured in OPEN position.
    • Now you can pull battery out by simply lifting it by that notch (3).
  2. Fujitsu Lifebook E546 RAM Modules Replacement, Removing RAM modules cover: 2 단계, 이미지 1개 중 1개
    • To remove RAM modules cover, just undo one screw (highlited in photo). Then lift cover by notch next to the screw hole.
  3. Fujitsu Lifebook E546 RAM Modules Replacement: 3 단계, 이미지 1개 중 1개
    • Now you can see you RAM modules bay. RAM stick is held by two clips - one at each side.
    • Gently pull the tabs outwards. Released RAM stick should pop-up upwards to certain angle.
    • Gently remove RAM stick. To insert a new stick, push it into slot at an angle. Make sure it is evenly seated, then push it down until clips will secure it.
결론
작성자
1다른 기여자 명과 함께
Michał Kurda
회원 가입일: 02/17/22
866 평판
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 290
