주요 콘텐츠로 건너뛰기
Fujitsu Lifebook S6120 Motherboard Replacement
Jessi Gallant
Jessi Gallant3 다른 기여자
최종 수정일 May 7, 2024
25 - 30 분
조정
추천 학생 안내서
If your computer is completely unresponsive and the motherboard needs to be replaced or repaired, this guide will show you how to remove the motherboard from the Fujitsu Lifebook S6120.
필요한 것
도구
더보기...
  1. Fujitsu Lifebook S6120 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Motherboard Replacement, Hinge Cover: 2 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement, Hinge Cover: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Motherboard Replacement, Keyboard: 6 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement, Keyboard: 6 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Motherboard Replacement, Keyboard: 6 단계, 이미지 3개 중 3개
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  8. Fujitsu Lifebook S6120 Motherboard Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
    • Use a Philips head #0 to remove the 5mm screws.
    • Use a Philips head #00 to remove the 4mm screws.
  9. Fujitsu Lifebook S6120 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Lift up the plastic frame from the base to expose the ribbon attached to the motherboard.
  10. Fujitsu Lifebook S6120 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the ribbon from the motherboard with a pair of tweezers.
  11. Fujitsu Lifebook S6120 Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Use a 5mm nut driver to unscrew the nuts.
  12. Fujitsu Lifebook S6120 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Pull the ribbon tab up and off the motherboard.
  13. Fujitsu Lifebook S6120 Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the metal plate covering the motherboard.
  14. Fujitsu Lifebook S6120 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the 3.5mm screws with a Philips head #0.
    • Remove the metal bracket and other pieces that rely on it for structure.
  15. Fujitsu Lifebook S6120 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Pinch your fingers around the base of the connector and pull it out.
  16. Fujitsu Lifebook S6120 Motherboard Replacement: 16 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Motherboard Replacement: 16 단계, 이미지 2개 중 2개
    • Lift the motherboard off the plastic base.
결론
작성자
3다른 기여자 명과 함께
Jessi Gallant
회원 가입일: 03/19/18
899 평판
안내서 7개를 작성함
UMass Dartmouth, Team S5-G5, Peak Spring 2018 UMass Dartmouth, Team S5-G5, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G5
3 회원들
안내서 18개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 1,187
