Fujitsu Lifebook UH572 Battery/RAM/HDD Door replacement
Use this guide to access the combined battery, RAM and hard drive compartment in a Fujitsu Lifebook UH572.
Remove the 6 black screws
To lift the cap use the opening tool.
There is a pit.
To reassemble your device, follow these instructions in reverse order. You have to press gently the cap in the reverse direction of the arrows, so the screws fit.
다른 4명이 해당 안내서를 완성하였습니다.
