주요 콘텐츠로 건너뛰기
Fuse Replacement for Semi-Integrated Battery, Rad Bikes
Eve
Eve2 다른 기여자
최종 수정일 June 21, 2024
1 시간
조정
커뮤니티-기여 안내서
Many people have accidentally stuck their metal key into the charge port of the Rad Power Bikes semi-integrated battery, causing the fuse to blow. This guide will walk you through the steps to replace your fuse. You may also find this video helpful: https://www.youtube.com/watch?v=Q287-kQN...
NOTE: If your battery is wrapped in blue plastic, you should be able to replace your fuse. If it's wrapped in black plastic, you may have a newer version of the battery with the fuse soldered on.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Fuse Replacement for Semi-Integrated Battery, Rad Bikes, Fuse: 1 단계, 이미지 1개 중 1개
    • Use a flathead screwdriver to pry into the end cap and then tap at an angle with a mallet to knock off end cap. This will reveal the screws underneath. Start with the end cap closest to the charge port. (You may not need to take off the other end, depending on how step 3 goes.)
  2. Fuse Replacement for Semi-Integrated Battery, Rad Bikes, Remove torx screws: 2 단계, 이미지 2개 중 1개 Fuse Replacement for Semi-Integrated Battery, Rad Bikes, Remove torx screws: 2 단계, 이미지 2개 중 2개
    • There are four torx 10 screws on each side. Two are easy to access, but the other two are buried deep in the recessed opening, so you’ll need a torx 10 screwdriver that can go deep.
  3. Fuse Replacement for Semi-Integrated Battery, Rad Bikes, Make sure fuse is accessible: 3 단계, 이미지 1개 중 1개
    • The fuse is at top left corner on charge port end of battery. Pull the blue casing out a bit to access it. If there is a lot of black rubber sealing your battery into place, you may need to open the other side so you can push it out from one end. Your goal is to get top portion of battery sticking out the top, making the fuse accessible.
  4. Fuse Replacement for Semi-Integrated Battery, Rad Bikes, Make a slit in blue plastic: 4 단계, 이미지 2개 중 1개 Fuse Replacement for Semi-Integrated Battery, Rad Bikes, Make a slit in blue plastic: 4 단계, 이미지 2개 중 2개
    • Use a utility knife to make a small slit so you can remove the broken fuse. Proceed slowly and carefully. To the right of the fuse there is a flat ribbon that conveys the battery status to the exterior lights. You don't want to accidentally cut through that.
  5. Fuse Replacement for Semi-Integrated Battery, Rad Bikes, Remove fuse: 5 단계, 이미지 1개 중 1개
    • You will see a red fuse with the number 10. You can pull it out using needle nose pliers.
  6. Fuse Replacement for Semi-Integrated Battery, Rad Bikes, Replace fuse: 6 단계, 이미지 1개 중 1개
    • Insert the working fuse in the same spot where you removed the broken one. Then, plug in your charger to confirm that both lights are red indicating it is fixed and now charging. If it works now, congrats!
  7. Fuse Replacement for Semi-Integrated Battery, Rad Bikes, Tape it up: 7 단계, 이미지 1개 중 1개
    • Use electrical tape to tape where you cut the slit. You could also try liquid electrical tape. Avoid using silicone with acetic acid since it can corrode the electronics in the battery pack.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Eve
회원 가입일: 08/01/22
316 평판
안내서 1개를 작성함
댓글 19개
Very good information! I had to slide out the battery also to get to the fuse. They probably changed the design so it was harder to change the fuse ourselves.
harvey - 답글
We replaced the fuse, but the battery doesn't charge up. What next?
Kathy Marshall - 답글
I have a Rad Rover 6 Plus. Battery wouldn't charge or even show a single bar on display and was not in "transport mode". I followed this guide but had to open BOTH sizes to cut the battery adhesive to be able to slide the batter about 1 or 2 inches as the 10 amp fuse was mounted deeper down on the RIGHT side. Note also that I found a 30amp fuse on the other side (opposite the charge port). It was still okay, but the 10amp fuse was toast. I replaced it and the battery is charging just fine!!!! Why don't they make this any easy fuse replacement. These are $600 batteries that shouldn't be replaced simply due to a 10 cent fuse!
Todd Nuttall - 답글
Hi where is the 30 amp fuse located? Is it on the same end of battery as the 10 amp fuse or other end?
Hd-sheri -
Does that 10amp mini red fuse need to be rated for voltage? Are there specific 10amp mini red fuses for 48v batteries or will any 10amp mini fuse do?
Bob Beaker - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 43
지난 30일: 176
전체 시간: 8,544
