주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fusion5 5.5 Gen II Fingerprint Sensor Replacement
필요한 것
  1. Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Hold the device with the screen facing away from you and the back of the device facing you.
    • Locate the groove at the bottom corner of the device.
    • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
    댓글 쓰기
  2. Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Midframe: 2 단계, 이미지 2개 중 1개 Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Midframe: 2 단계, 이미지 2개 중 2개
    • Remove thirteen 3mm Phillips #00 screws from the midframe.
    • Remove the single 5mm Phillips #0 screw below the camera.
    댓글 쓰기
  3. Fusion5 5.5 Gen II Fingerprint Sensor Replacement: 3 단계, 이미지 2개 중 1개 Fusion5 5.5 Gen II Fingerprint Sensor Replacement: 3 단계, 이미지 2개 중 2개
    • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
    • Be careful not to damage the cables inside the device when you pry the midframe off.
    댓글 쓰기
  4. Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Fingerprint Sensor: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, flip the brown tab securing the ribbon cable.
    • Make sure to only lift the flap and not the connector socket due to its susceptibility to break off.
    댓글 쓰기
  5. Fusion5 5.5 Gen II Fingerprint Sensor Replacement: 5 단계, 이미지 3개 중 1개 Fusion5 5.5 Gen II Fingerprint Sensor Replacement: 5 단계, 이미지 3개 중 2개 Fusion5 5.5 Gen II Fingerprint Sensor Replacement: 5 단계, 이미지 3개 중 3개
    • Using the tweezers, grab the ribbon cable and pull it out from its connector.
    • Remove the fingerprint sensor from its socket on the motherboard.
    • When re-installing the fingerprint sensor, make sure to align the ribbon cable with the plastic socket on the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Hwajin
회원 가입일: 09/16/19
566 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 37
전체 시간: 599
