주요 콘텐츠로 건너뛰기
GATEWAY NE56R09u Hard Drive Replacement
joshua depina
joshua depina4 다른 기여자
최종 수정일 June 23, 2022
3 - 4 분
조정
더 나은 이미지가 필요함
학생이 작성 중
Due to improper ventilation or faulty CPU fan, a system would heat to the peak point and leads to the sudden hard drive crash, it is very important to practice safety measures when dealing with the laptop. Never try to replace a hard drive as soon as it crashes, due to heating of material within the casing of the laptop if overheating. Before attempting to do a replacement, make sure your device is powered off and make sure to read through the guide first before jumping straight into a repair. Safety is always first!
필요한 것
도구
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. GATEWAY NE56R09u Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
  2. GATEWAY NE56R09u Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Using a nylon spudger or your fingers, push down on the battery clip to release the battery.
  3. GATEWAY NE56R09u Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery.
  4. GATEWAY NE56R09u Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
    • Using the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the hard drive. These 2 screws are what is also keeping the hard drive in place.
  5. GATEWAY NE56R09u Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Push firmly down on the center of the hard drive and with a swiping to the left motion release the clip from the drive.
  6. GATEWAY NE56R09u Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Once the drive has been released, simple lift up the hard drive to remove it.
결론
To reassemble your device, please follow these instructions in reverse order.
작성자
4다른 기여자 명과 함께
joshua depina
회원 가입일: 03/25/19
401 평판
안내서 3개를 작성함
UMass Dartmouth, Team S6-G1, Peak Spring 2019 UMass Dartmouth, Team S6-G1, Peak Spring 2019 회원
UMASSD-PEAK-S19S6G1
2 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 243
