주요 콘텐츠로 건너뛰기
GEHEN Portable Clip-On Fan Battery Replacement
Regina Ramirez
Regina Ramirez2 다른 기여자
최종 수정일 June 19, 2024
15 - 25 분
쉬움
If your GEHEN Portable Clip-On Fan no longer turns on or the fan doesn't charge anymore, perhaps it is time to replace the battery. Over time, lithium batteries can begin to lose their efficiency or even stop working altogether. A battery change is needed despite the remaining components being fully functional inside the GEHEN Portable Clip-On Fan. Using a couple of tools, we will go over the steps necessary to replace the battery to extend the shelf life of the GEHEN Portable Clip-On Fan. Along with changing the battery, we will also go over how to dispose of the old batteries properly.
Warning: If one or both of the batteries inside the GEHEN Portable Clip-On Fan are visibly swollen when replacing, take the necessary precautions for dealing with a swollen battery as they can be dangerous and potentially cause a fire. For more information on how to deal with a swollen battery, take a look at this blog post on What to Do With a Swollen iPhone Battery.
필요한 것
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. GEHEN Portable Clip-On Fan Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 GEHEN Portable Clip-On Fan Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 GEHEN Portable Clip-On Fan Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Flip the fan over so the back panel is facing you.
  2. GEHEN Portable Clip-On Fan Battery Replacement: 2 단계, 이미지 3개 중 1개 GEHEN Portable Clip-On Fan Battery Replacement: 2 단계, 이미지 3개 중 2개 GEHEN Portable Clip-On Fan Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips #3 screwdriver to remove the two 20 mm screws from the back panel of the fan.
  3. GEHEN Portable Clip-On Fan Battery Replacement: 3 단계, 이미지 3개 중 1개 GEHEN Portable Clip-On Fan Battery Replacement: 3 단계, 이미지 3개 중 2개 GEHEN Portable Clip-On Fan Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Use a spudger to pry the back panel from the fan.
    • If you can't pry between the seam of the panel and the slats, use the empty screw holes to lift the panel up with the pointed end of the spudger.
    • The battery pack is situated in the back panel of the fan, but it is also attached to the body. When removing it, avoid pulling or yanking on the back panel.
  4. GEHEN Portable Clip-On Fan Battery Replacement: 4 단계, 이미지 3개 중 1개 GEHEN Portable Clip-On Fan Battery Replacement: 4 단계, 이미지 3개 중 2개 GEHEN Portable Clip-On Fan Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Squeeze the tab against the power cable connector, and pull the connector straight up from the socket.
  5. GEHEN Portable Clip-On Fan Battery Replacement: 5 단계, 이미지 3개 중 1개 GEHEN Portable Clip-On Fan Battery Replacement: 5 단계, 이미지 3개 중 2개 GEHEN Portable Clip-On Fan Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully peel off the tape from both ends of the batteries.
    • Save the battery end protectors to use when reassembling your fan.
  6. GEHEN Portable Clip-On Fan Battery Replacement: 6 단계, 이미지 3개 중 1개 GEHEN Portable Clip-On Fan Battery Replacement: 6 단계, 이미지 3개 중 2개 GEHEN Portable Clip-On Fan Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Use tin snips to carefully remove the thin piece of metal that connects the ends of the two batteries.
    • Repeat this step on both ends.
    • Since you will need to reuse these metal pieces, be extra careful when cutting them from the batteries. Preserve as much as possible to retain the length of the metal strip.
    • Don't accidentally cut the wires when removing the thing metal!
  7. GEHEN Portable Clip-On Fan Battery Replacement: 7 단계, 이미지 2개 중 1개 GEHEN Portable Clip-On Fan Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Once the wires are disconnected, the old batteries can be properly disposed of.
  8. GEHEN Portable Clip-On Fan Battery Replacement: 8 단계, 이미지 3개 중 1개 GEHEN Portable Clip-On Fan Battery Replacement: 8 단계, 이미지 3개 중 2개 GEHEN Portable Clip-On Fan Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Place electrical tape over the ends of each battery.
    • Take it to a hazardous waste collection point or to a store that cooperates with the disposal of industrial waste and battery recycling such as an electronics store or a home center.
  9. GEHEN Portable Clip-On Fan Battery Replacement: 9 단계, 이미지 3개 중 1개 GEHEN Portable Clip-On Fan Battery Replacement: 9 단계, 이미지 3개 중 2개 GEHEN Portable Clip-On Fan Battery Replacement: 9 단계, 이미지 3개 중 3개
    • Take the new batteries and reattach the connector.
    • Use the tape cover that was set aside earlier and apply one on each end of the batteries.
    • If necessary, use additional electrical tape to secure the connectors on the ends of the battery pack.
    • Try to not pull or push on the red and black wires to avoid disconnection.
    • Place the battery pack back into the holder on the back panel.
  10. GEHEN Portable Clip-On Fan Battery Replacement: 10 단계, 이미지 3개 중 1개 GEHEN Portable Clip-On Fan Battery Replacement: 10 단계, 이미지 3개 중 2개 GEHEN Portable Clip-On Fan Battery Replacement: 10 단계, 이미지 3개 중 3개
    • Replace the back panel the two 20 mm screws using the Phillips #3 screwdriver.
  11. GEHEN Portable Clip-On Fan Battery Replacement: 11 단계, 이미지 3개 중 1개 GEHEN Portable Clip-On Fan Battery Replacement: 11 단계, 이미지 3개 중 2개 GEHEN Portable Clip-On Fan Battery Replacement: 11 단계, 이미지 3개 중 3개
    • Once the back panel has been fastened, ensure that the fan works by pressing the button repeatedly until all the LEDs turn on.
결론
작성자
2다른 기여자 명과 함께
Regina Ramirez
회원 가입일: 03/05/24
193 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 4
전체 시간: 121
