주요 콘텐츠로 건너뛰기
GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair
TUOYO FABIYI
TUOYO FABIYI2 다른 기여자
최종 수정일 January 21, 2025
30 분
쉬움
헷갈리는 텍스트
Many people can find it difficult to fix a broken fan even though, most of the time, it's quite easy. No particular skills are required, many of the processes are simple, and you only need to know how to use a screwdriver. There is minimal risk; it is advised to unplug the fan from any outlet because that is the only possible danger.
This manual is crucial since it deconstructs and makes repair of any damaged fan simple. The main goal of this article is to make it clearer how to fix a broken GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair, GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 1 단계, 이미지 2개 중 1개 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair, GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 1 단계, 이미지 2개 중 2개
    • Take out the front metal grill.
    • By the side of the cover, there's a metal piece you have to flick open to get the front and back unlocked from each other.
  2. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 2 단계, 이미지 2개 중 1개 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 2 단계, 이미지 2개 중 2개
    • Turn the knob to take out the blade cap.
    • Spin the knob counterclockwise. This way, you are loosening the knob.
  3. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 3 단계, 이미지 2개 중 1개 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 3 단계, 이미지 2개 중 2개
    • Loosen the plastic nut on the rear grille in order to take the rear grille out.
  4. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 4 단계, 이미지 2개 중 1개 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 4 단계, 이미지 2개 중 2개
    • Unscrew the plastic on the fan motor, and gently pull the slide open: There are four screws, proceed to taking off the plastic plates.
  5. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 5 단계, 이미지 2개 중 1개 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 5 단계, 이미지 2개 중 2개
    • Apply machine oil onto the rusted parts.
    • Take the machine oil and make sure you apply the oil to the around fan rotor
    • Let the oil stay for about 5 minutes
    • Do not spill the oil on the surface or let the oil go into the rotor.
  6. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 6 단계, 이미지 2개 중 1개 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 6 단계, 이미지 2개 중 2개
    • Carefully place the plastic plate properly on the surface of the fan rotor.
    • Make sure the screws align with the holes on the fan motor, then proceed to screw.
  7. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 7 단계, 이미지 1개 중 1개
    • Place back the fan rear grill, pick up the plastic grill nut.
    • fit in the hole and screw down the fan rear grill upon the fan motor.
  8. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 8 단계, 이미지 1개 중 1개
    • Place the blade right back into the motor pin.
    • Take the blade, make sure the blade sit on the fan edges.
  9. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 9 단계, 이미지 1개 중 1개
    • Take the circlip, spin the circlip right on the blade, ensure it is tight.
  10. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 10 단계, 이미지 1개 중 1개
    • Pick up the front grille, ensure the grille aligns with the metal piece around the fan.
    • Then lock the metal piece, this way the front and the rear grilles are locked.
    • If the metal piece do not align, you would have issues locking the grilles to each other.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
TUOYO FABIYI
회원 가입일: 09/08/23
238 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 57
전체 시간: 434
