주요 콘텐츠로 건너뛰기
GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair
필요한 것
  1. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair, GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 1 단계, 이미지 2개 중 1개 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair, GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 1 단계, 이미지 2개 중 2개
    • Take out the front metal grill.
    • Flick open the metal piece, located by the side of the cover, to get the front and back of the grille unlocked from each other.
  2. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 2 단계, 이미지 2개 중 1개 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 2 단계, 이미지 2개 중 2개
    • Turn the knob counterclockwise to take out the blade cap.
  3. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 3 단계, 이미지 2개 중 1개 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 3 단계, 이미지 2개 중 2개
    • Loosen the plastic nut on the rear grille and then take the rear grille out.
  4. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 4 단계, 이미지 2개 중 1개 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 4 단계, 이미지 2개 중 2개
    • Unscrew the plastic on the fan motor, and gently pull the slide open: There are four screws, proceed to taking off the plastic plates.
  5. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 5 단계, 이미지 2개 중 1개 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 5 단계, 이미지 2개 중 2개
    • Apply machine oil onto any rusted parts, making sure you apply it around, but not in, the fan rotor.
    • Let the oil sit for about 5 minutes
    • Do not spill the oil on the surface or into the rotor.
  6. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 6 단계, 이미지 2개 중 1개 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 6 단계, 이미지 2개 중 2개
    • Carefully place the plastic plate properly on the surface of the fan rotor.
    • Make sure the screws align with the holes on the fan motor, then proceed to screw.
  7. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 7 단계, 이미지 1개 중 1개
    • Place the fan rear grille back into its original position and pick up the plastic grill nut.
    • Screw the rear grille onto the fan motor.
  8. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 8 단계, 이미지 1개 중 1개
    • Place the blade back onto the motor pin, making sure it sits on the edges of the fan.
  9. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 9 단계, 이미지 1개 중 1개
    • Take the circlip and tighten it well onto the blade.
  10. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: 10 단계, 이미지 1개 중 1개
    • Pick up the front grille and align it with the metal piece around the fan.
    • Lock the metal piece, so that both the front and rear grilles are locked.
    • If the metal pieces do not align, you will have issues locking the grilles to each other.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
TUOYO FABIYI
회원 가입일: 09/08/23
238 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 54
전체 시간: 1,000
