주요 콘텐츠로 건너뛰기
GT Aggressor Pro Mountain Front Wheel Spoke Replacement
Ronaldo Pascual
Ronaldo Pascual3 다른 기여자
최종 수정일 June 19, 2023
30 분 - 1 시간
조정
This repair guide will direct a beginner or intermediate bike enthusiast through all the steps needed to replace a damaged or broken spoke on a bicycle.
The bicycle used in the fix was a GT Men's Aggressor Pro Mountain Bike. The steps in the guide were specifically designed for this bike model. Please note that even though most mountain bikes would require the same steps, some small discrepancies in parts on other bikes may make this fix unsuccessful on different models.
This guide only applies to the front wheel as the steps to removing the wheel differ on the back wheel. If taking the back wheel off and putting it back on is not an issue, steps 4-17 are the same for the rear wheel. It is important to note that this fix will be much easier with a friend or in a group; doing it alone can pose challenges.
  1. GT Aggressor Pro Mountain Front Wheel Spoke Replacement, Front Wheel Spoke: 1 단계, 이미지 3개 중 1개 GT Aggressor Pro Mountain Front Wheel Spoke Replacement, Front Wheel Spoke: 1 단계, 이미지 3개 중 2개 GT Aggressor Pro Mountain Front Wheel Spoke Replacement, Front Wheel Spoke: 1 단계, 이미지 3개 중 3개
    • Placing your bike on a stand or having a friend hold the bike will make the repair easier to perform.
    • Pull the quick-release lever on the front wheel of the bike and turn it to loosen it.
  2. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 2 단계, 이미지 2개 중 1개 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the quick-release lever.
  3. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 3 단계, 이미지 2개 중 1개 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the fork from the axle of the wheel.
  4. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 4 단계, 이미지 2개 중 1개 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the cap from the Presta air valve that is located between the spokes on the rim.
  5. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 5 단계, 이미지 1개 중 1개
    • Push up on the Presta valve to release the air in the inner tube.
  6. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 6 단계, 이미지 2개 중 1개 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 6 단계, 이미지 2개 중 2개
    • Twist the valve to remove the nut from it.
  7. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 7 단계, 이미지 3개 중 1개 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 7 단계, 이미지 3개 중 2개 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the tire and inner tube from the rim.
    • It is possible to do this with your hands but using a tire lever would simplify the process.
  8. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 8 단계, 이미지 3개 중 1개 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 8 단계, 이미지 3개 중 2개 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 8 단계, 이미지 3개 중 3개
    • Loosen the spoke by using the spoke wrench.
    • Use a flat head screwdriver to remove the screw corresponding to the damaged or broken spoke.
  9. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 9 단계, 이미지 1개 중 1개
    • Use a T25 screwdriver to remove the six 10.0 mm screws from the disk brake rotor.
  10. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 10 단계, 이미지 2개 중 1개 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 10 단계, 이미지 2개 중 2개
    • Unthread and remove the spoke from the rim and the hub.
    • Make sure to look at the alignment of the spoke removed in order to put the new spoke back on the same way.
    • The spoke will come out of the hole.
  11. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 11 단계, 이미지 1개 중 1개
    • Thread the new spoke into the rim.
    • Make sure the alignment/placement of the new spoke is the same as the old one.
결론
Thank you for using our guide. Enjoy getting back on the trails or roads!
작성자
3다른 기여자 명과 함께
Ronaldo Pascual
회원 가입일: 02/10/23
193 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 20
지난 30일: 53
전체 시간: 906
