주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Game Boy Advance Motherboard Replacement
필요한 것
  1. Game Boy Advance Motherboard Replacement, Prepare your Game Boy for disassembly: 1 단계, 이미지 2개 중 1개 Game Boy Advance Motherboard Replacement, Prepare your Game Boy for disassembly: 1 단계, 이미지 2개 중 2개
    • Before working on your Game Boy, turn the power switch to the OFF position and unplug any cables.
    • If you have a game cartridge installed, remove it.
    • Since your Game Boy will be laying screen‑side down for most of your repair, consider placing it on a clean cloth for protection.
    댓글 쓰기
  2. Game Boy Advance Motherboard Replacement, Remove the battery cover: 2 단계, 이미지 3개 중 1개 Game Boy Advance Motherboard Replacement, Remove the battery cover: 2 단계, 이미지 3개 중 2개 Game Boy Advance Motherboard Replacement, Remove the battery cover: 2 단계, 이미지 3개 중 3개
    • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
    • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
    댓글 쓰기
  3. Game Boy Advance Motherboard Replacement, Remove the batteries: 3 단계, 이미지 3개 중 1개 Game Boy Advance Motherboard Replacement, Remove the batteries: 3 단계, 이미지 3개 중 2개 Game Boy Advance Motherboard Replacement, Remove the batteries: 3 단계, 이미지 3개 중 3개
    • Remove the two AA batteries.
    • If the metal terminals are corroded, follow this guide to clean them.
    • When installing batteries, use the diagram in the battery well to properly orient them.
    댓글 쓰기
  4. Game Boy Advance Motherboard Replacement, Remove the back shell screws: 4 단계, 이미지 2개 중 1개 Game Boy Advance Motherboard Replacement, Remove the back shell screws: 4 단계, 이미지 2개 중 2개
    • Remove the seven screws securing the back shell:
    • Six 9.4 mm‑long tri‑point Y0 screws
    • One 8.5 mm‑long JIS 1 screw
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
    댓글 쓰기
  5. Game Boy Advance Motherboard Replacement, Remove the back shell: 5 단계, 이미지 2개 중 1개 Game Boy Advance Motherboard Replacement, Remove the back shell: 5 단계, 이미지 2개 중 2개
    • Lift the back shell straight up and remove it.
    • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
    댓글 쓰기
  6. Game Boy Advance Motherboard Replacement, Remove the shoulder buttons: 6 단계, 이미지 3개 중 1개 Game Boy Advance Motherboard Replacement, Remove the shoulder buttons: 6 단계, 이미지 3개 중 2개 Game Boy Advance Motherboard Replacement, Remove the shoulder buttons: 6 단계, 이미지 3개 중 3개
    • Lift the shoulder buttons (aka L and R buttons) straight up to remove them.
    • During reassembly:
    • Since your Game Boy is laying upside down, the L button will go on your right‑hand side, and the R button will go on your left‑hand side.
    • Slide the buttons into place, making sure the peg on the button goes into its circular cutout and the button itself is over the actual button mechanism.
    • The shoulder buttons will sit on the inside edge of the side bumpers.
    • Gently test the buttons to make sure they feel correct. If they don't, reposition them and make sure the metal arms aren't stuck in a weird position under the board.
    댓글 쓰기
  7. Game Boy Advance Motherboard Replacement, Remove the side bumpers: 7 단계, 이미지 3개 중 1개 Game Boy Advance Motherboard Replacement, Remove the side bumpers: 7 단계, 이미지 3개 중 2개 Game Boy Advance Motherboard Replacement, Remove the side bumpers: 7 단계, 이미지 3개 중 3개
    • Remove the side bumpers.
    댓글 쓰기
  8. Game Boy Advance Motherboard Replacement, Remove the power switch cover: 8 단계, 이미지 2개 중 1개 Game Boy Advance Motherboard Replacement, Remove the power switch cover: 8 단계, 이미지 2개 중 2개
    • Remove the power switch cover.
    • During reassembly, make sure the switch cover is properly slotted around the arm on the switch mechanism.
    댓글 쓰기
  9. Game Boy Advance Motherboard Replacement, Disconnect the screen cable: 9 단계, 이미지 3개 중 1개 Game Boy Advance Motherboard Replacement, Disconnect the screen cable: 9 단계, 이미지 3개 중 2개 Game Boy Advance Motherboard Replacement, Disconnect the screen cable: 9 단계, 이미지 3개 중 3개
    • Use the point of a spudger to fully push up both locking tabs on either side of the screen cable connector.
    • You should feel the tab click into its unlocked position. Don't push too far, or the tab may slide completely out of the connector.
    댓글 쓰기
  10. Game Boy Advance Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Game Boy Advance Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Use tweezers to slide the cable straight out of its socket.
    • The cable should come out with little to no force. If you feel resistance, the tab may not be fully unlocked.
    댓글 쓰기
  11. Game Boy Advance Motherboard Replacement, Remove the motherboard screws: 11 단계, 이미지 2개 중 1개 Game Boy Advance Motherboard Replacement, Remove the motherboard screws: 11 단계, 이미지 2개 중 2개
    • Use a JIS 1 screwdriver to remove the three 7 mm‑long screws securing the motherboard.
    댓글 쓰기
  12. Game Boy Advance Motherboard Replacement, Remove the motherboard: 12 단계, 이미지 3개 중 1개 Game Boy Advance Motherboard Replacement, Remove the motherboard: 12 단계, 이미지 3개 중 2개 Game Boy Advance Motherboard Replacement, Remove the motherboard: 12 단계, 이미지 3개 중 3개
    • Use your fingers to grip the cartridge reader and lift the motherboard straight up to remove it.
    • During reassembly, make sure the speaker gets correctly slotted into its circular cutout (including a small tab on the bottom) when lowering the motherboard into place.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
195,088 평판
안내서 1,243개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 70
지난 30일: 253
전체 시간: 22,869
