주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GameSir Nova 2 Lite Button Replacement
필요한 것
  1. GameSir Nova 2 Lite Button Replacement, Battery: 1 단계, 이미지 2개 중 1개 GameSir Nova 2 Lite Button Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Before you take your controller apart make sure it is powered off by holding the power button down for 15 seconds until it stops blinking.
    • Use a Phillips #0 screwdriver to remove the four 8.5 mm screws from the bottom of the controller's casing.
    댓글 쓰기
  2. GameSir Nova 2 Lite Button Replacement: 2 단계, 이미지 3개 중 1개 GameSir Nova 2 Lite Button Replacement: 2 단계, 이미지 3개 중 2개 GameSir Nova 2 Lite Button Replacement: 2 단계, 이미지 3개 중 3개
    • Insert an opening tool between the two halves to open the controller's casing.
    • You will feel several internal latches called “snap-fit connectors.”
    • Disconnect them by sliding the opening tool along the seam in the casing, applying continuous pressure.
    • Once you find a connector, apply increased pressure until you hear a snapping sound.
    • Repeat this process until all of the connectors are disconnected.
    • Separate the top and bottom of the controller case.
    댓글 쓰기
  3. GameSir Nova 2 Lite Button Replacement: 3 단계, 이미지 2개 중 1개 GameSir Nova 2 Lite Button Replacement: 3 단계, 이미지 2개 중 2개
    • Set aside the bottom half of the shell.
    • Position the controller so that the motherboard is visible.
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    댓글 쓰기
  4. GameSir Nova 2 Lite Button Replacement: 4 단계, 이미지 2개 중 1개 GameSir Nova 2 Lite Button Replacement: 4 단계, 이미지 2개 중 2개
    • If the battery appears swollen follow this link.
    • The battery is held in place by double-sided adhesive.
    • Use a spudger to loosen the tape securing the battery.
    • Remove the battery from the controller.
    댓글 쓰기
  5. GameSir Nova 2 Lite Button Replacement, Rumble Motor: 5 단계, 이미지 2개 중 1개 GameSir Nova 2 Lite Button Replacement, Rumble Motor: 5 단계, 이미지 2개 중 2개
    • Push on alternating sides of the JST connector to release it from the socket on the circuit board.
    댓글 쓰기
  6. GameSir Nova 2 Lite Button Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the motor out of its socket.
    • Repeat the steps for the other rumble motor.
    댓글 쓰기
  7. GameSir Nova 2 Lite Button Replacement, Buttons: 7 단계, 이미지 3개 중 1개 GameSir Nova 2 Lite Button Replacement, Buttons: 7 단계, 이미지 3개 중 2개 GameSir Nova 2 Lite Button Replacement, Buttons: 7 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the six 5.7 mm screws securing the motherboard.
    • Separate the midframe that holds the motherboard from the outer shell.
    댓글 쓰기
  8. GameSir Nova 2 Lite Button Replacement: 8 단계, 이미지 3개 중 1개 GameSir Nova 2 Lite Button Replacement: 8 단계, 이미지 3개 중 2개 GameSir Nova 2 Lite Button Replacement: 8 단계, 이미지 3개 중 3개
    • At this point the only thing holding the buttons in place is gravity.
    • Remove the buttons from the top case.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jonathan McMillin
회원 가입일: 09/29/25
185 평판
안내서 1개를 작성함
1가이드 댓글
I .... where to find the ( new stick )for the controller Gamesir ?
Leandro Montiel - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 30
지난 30일: 149
전체 시간: 937
