주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GameSir Tarantula Pro Joystick Cover Replacement
필요한 것
  1. GameSir Tarantula Pro Joystick Cover Replacement, Joystick Covers: 1 단계, 이미지 3개 중 1개 GameSir Tarantula Pro Joystick Cover Replacement, Joystick Covers: 1 단계, 이미지 3개 중 2개 GameSir Tarantula Pro Joystick Cover Replacement, Joystick Covers: 1 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to remove the rubber screw covers from the backs of the handles and the top edge of the back case.
    • Gently pry up each screw cover and lift it out.
    댓글 쓰기
  2. GameSir Tarantula Pro Joystick Cover Replacement: 2 단계, 이미지 2개 중 1개 GameSir Tarantula Pro Joystick Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the 4.0 mm screws from the back case.
    • Because the screws are deeply recessed, use a long, thin driver to remove them.
    댓글 쓰기
  3. GameSir Tarantula Pro Joystick Cover Replacement: 3 단계, 이미지 2개 중 1개 GameSir Tarantula Pro Joystick Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Slide a spudger around the seam between the top and bottom cases to release the retaining clips.
    • Remove the bottom case.
    댓글 쓰기
  4. GameSir Tarantula Pro Joystick Cover Replacement: 4 단계, 이미지 3개 중 1개 GameSir Tarantula Pro Joystick Cover Replacement: 4 단계, 이미지 3개 중 2개 GameSir Tarantula Pro Joystick Cover Replacement: 4 단계, 이미지 3개 중 3개
    • Use the Phillips #000 screwdriver to remove the nine 4.0 mm screws from the motherboard.
    댓글 쓰기
  5. GameSir Tarantula Pro Joystick Cover Replacement: 5 단계, 이미지 3개 중 1개 GameSir Tarantula Pro Joystick Cover Replacement: 5 단계, 이미지 3개 중 2개 GameSir Tarantula Pro Joystick Cover Replacement: 5 단계, 이미지 3개 중 3개
    • Use the point of a spudger to push on alternating sides of each JST connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • If the connector's socket has cutouts, you can insert the arms of a pair of sharp tweezers into the cutouts and gently push the connector out of its socket.
    • Carefully remove the battery from the controller.
    • Avoid bending or puncturing the battery.
    • The battery is secured by double-sided tape, so it may take some work to loosen the adhesive before you can completely remove the battery. Use the iFixit adhesive remover if you have trouble removing the battery.
    댓글 쓰기
  6. GameSir Tarantula Pro Joystick Cover Replacement: 6 단계, 이미지 2개 중 1개 GameSir Tarantula Pro Joystick Cover Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully remove the motherboard from the shell.
    • Flip the motherboard over so the joysticks are facing upward.
    댓글 쓰기
  7. GameSir Tarantula Pro Joystick Cover Replacement: 7 단계, 이미지 3개 중 1개 GameSir Tarantula Pro Joystick Cover Replacement: 7 단계, 이미지 3개 중 2개 GameSir Tarantula Pro Joystick Cover Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the joysticks by gently pulling them up and off their mounts.
    • When installing the new joystick covers, press them down onto the joysticks until you hear a click, indicating they are securely locked in place.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Eduardo Pereira
회원 가입일: 03/02/26
195 평판
안내서 1개를 작성함
UMass Dartmouth, Team 3-5, Shaddix Spring 2026 UMass Dartmouth, Team 3-5, Shaddix Spring 2026 회원
UMASSD-SHADDIX-S26S3G5
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 32
지난 30일: 138
전체 시간: 227
